跳转到主内容
BenQ HT1075 Projector Bulb Replacement
你所需要的
  1. BenQ HT1075 Projector Bulb Replacement, Lamp: 步骤 1 中的图像 1,1
    • Loosen the 2.5 mm Phillips #1 screw that holds the top assembly in place using a Philips #1 (PH1) screwdriver. This will enable you to lift and slide off the top cover.
    • Fully remove the top cover in order to get to the lamp housing.
  2. BenQ HT1075 Projector Bulb Replacement: 步骤 2 中的图像 1,1
    • Carefully peel off the adhesive film covering the lamp housing.
  3. BenQ HT1075 Projector Bulb Replacement: 步骤 3 中的图像 1,1
    • Using a Phillips #1 (PH1) screwdriver, loosen and remove the single 2.5 mm Phillips #1 screw that secures the lamp housing to the projector.
  4. BenQ HT1075 Projector Bulb Replacement: 步骤 4 中的图像 1,1
    • Remove the lamp from the projector by pulling on the lamp handle.
    • Apply more force on the side opposite of the newly removed screw as you pull the lamp out.
  5. BenQ HT1075 Projector Bulb Replacement, Bulb: 步骤 5 中的图像 1,1
    • Using a Philips #0 (PH0) screwdriver, remove the two screws holding the metal case of the lamp housing.
  6. BenQ HT1075 Projector Bulb Replacement: 步骤 6 中的图像 1,1
    • Using a 2.5mm Hex key, remove the top portion that contains the handle. This portion is also attached to the bulb housing.
  7. BenQ HT1075 Projector Bulb Replacement: 步骤 7 中的图像 1,1
    • With a Philips #0 (PH0) screwdriver, remove the four screws that secure the bulb to the housing unit.
  8. BenQ HT1075 Projector Bulb Replacement: 步骤 8 中的图像 1,1
    • Using a Philips#1 (PH1) screwdriver, remove the 2.5 mm Phillips #1 screw that secures the wires to the detach bulb.
结论
3等其他人完成本指南。
Gabriela Remulla
于09/26/17注册
1,008 声望
创作了5篇指南
团队
Cal Poly, Team S6-G1, Banghart Fall 2017 Cal Poly, Team S6-G1, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S6G1
5 名成员
创作了9篇指南
4指南评论
Hey, Thanks for sharing the steps setting a Project Bulb Replacement.
SupplyExpert - 回复
we recently replaced Ht 1075 bulb after the main bulb broke. the projector runs for 10 min and them shuts off due to overheating. previously that was not the case. what could be the issue and how we can isolate and fix the issue..
Subcon App - 回复
From my experience try replacing the main blower fan located under the motherboard
Robert Koss -
we had the same experience as Subcon App - bought OEM complete lamp unit replacement when original exceeded maximum life, but as soon as we replaced the new BenQ one for the old one the projector now works for about 3-5 minutes and then shuts off from overheating. really very frustrating.
Will Thompson - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 39
总计 3,747
