跳转到主内容
加入维修社区 - 创建账户
Bella Pro 90246 Light Bulb Replacement
你所需要的
  1. Bella Pro 90246 Light Bulb Replacement, Light Bulb: 步骤 1 中的图像 1,1
    • Make sure your air fryer is unplugged to avoid the risk of being electrocuted.
    • Gather your materials to begin disassembly.
  2. Bella Pro 90246 Light Bulb Replacement: 步骤 2 中的图像 1,3 Bella Pro 90246 Light Bulb Replacement: 步骤 2 中的图像 2,3 Bella Pro 90246 Light Bulb Replacement: 步骤 2 中的图像 3,3
    • Use the metal spudger to pry off the protective lid on all four sides.
  3. Bella Pro 90246 Light Bulb Replacement: 步骤 3 中的图像 1,2 Bella Pro 90246 Light Bulb Replacement: 步骤 3 中的图像 2,2
    • Remove the three 9.5 mm screws on the top of the air fryer that hold the plastic cover in place using a Phillips #1 screwdriver.
  4. Bella Pro 90246 Light Bulb Replacement: 步骤 4 中的图像 1,3 Bella Pro 90246 Light Bulb Replacement: 步骤 4 中的图像 2,3 Bella Pro 90246 Light Bulb Replacement: 步骤 4 中的图像 3,3
    • Use the Phillips #1 screwdriver to remove the four 34.9 mm screws that are located inside the round holes on the corners of the plastic cover.
    • You may need to use a pair of needle nose pliers to remove the screws from the deep set holes.
  5. Bella Pro 90246 Light Bulb Replacement: 步骤 5 中的图像 1,2 Bella Pro 90246 Light Bulb Replacement: 步骤 5 中的图像 2,2
    • Open the door.
  6. Bella Pro 90246 Light Bulb Replacement: 步骤 6 中的图像 1,3 Bella Pro 90246 Light Bulb Replacement: 步骤 6 中的图像 2,3 Bella Pro 90246 Light Bulb Replacement: 步骤 6 中的图像 3,3
    • Press the button underneath the hood to release the mechanism that holds the door in place.
    • Once the door is disconnected, remove it from the airfryer and set it to the side.
  7. Bella Pro 90246 Light Bulb Replacement: 步骤 7 中的图像 1,2 Bella Pro 90246 Light Bulb Replacement: 步骤 7 中的图像 2,2
    • Carefully tilt the air fryer onto its side.
  8. Bella Pro 90246 Light Bulb Replacement: 步骤 8 中的图像 1,3 Bella Pro 90246 Light Bulb Replacement: 步骤 8 中的图像 2,3 Bella Pro 90246 Light Bulb Replacement: 步骤 8 中的图像 3,3
    • Use the Phillips #1 screwdriver to remove the three 25.4 mm screws under the hood.
  9. Bella Pro 90246 Light Bulb Replacement: 步骤 9 中的图像 1,1
    • Hold the top of the air fryer into place while carefully moving it back to its up-right position.
    • After removing the screws, the top will be loose. Hold firmly to avoid damage to any wire connections underneath the plastic cover.
  10. Bella Pro 90246 Light Bulb Replacement: 步骤 10 中的图像 1,3 Bella Pro 90246 Light Bulb Replacement: 步骤 10 中的图像 2,3 Bella Pro 90246 Light Bulb Replacement: 步骤 10 中的图像 3,3
    • Identify the grey electrical cable attached to the circuit board.
    • Press firmly on the cable head's tab to release the connection.
    • Carefully wiggle the cable head to disconnect the wire from the circuit board without damaging it.
  11. Bella Pro 90246 Light Bulb Replacement: 步骤 11 中的图像 1,2 Bella Pro 90246 Light Bulb Replacement: 步骤 11 中的图像 2,2
    • Lift the top cover off of the air fryer to access the electrical circuits underneath.
  12. Bella Pro 90246 Light Bulb Replacement: 步骤 12 中的图像 1,3 Bella Pro 90246 Light Bulb Replacement: 步骤 12 中的图像 2,3 Bella Pro 90246 Light Bulb Replacement: 步骤 12 中的图像 3,3
    • Remove the two 19.1 mm screws securing the metal light bulb cover using a Phillips #1 screwdriver.
    • Carefully pull off the metal cover to reveal the burnt-out light bulb.
  13. Bella Pro 90246 Light Bulb Replacement: 步骤 13 中的图像 1,3 Bella Pro 90246 Light Bulb Replacement: 步骤 13 中的图像 2,3 Bella Pro 90246 Light Bulb Replacement: 步骤 13 中的图像 3,3
    • The light bulb is made of glass and can be fragile. Handle with care to avoid injuring yourself with broken shards of glass.
    • Lift the light bulb circuit out of the plastic slot and remove the burnt out light bulb by pulling gently.
  14. Bella Pro 90246 Light Bulb Replacement: 步骤 14 中的图像 1,3 Bella Pro 90246 Light Bulb Replacement: 步骤 14 中的图像 2,3 Bella Pro 90246 Light Bulb Replacement: 步骤 14 中的图像 3,3
    • Gently plug the new light bulb into the light bulb circuit.
  15. Bella Pro 90246 Light Bulb Replacement: 步骤 15 中的图像 1,2 Bella Pro 90246 Light Bulb Replacement: 步骤 15 中的图像 2,2
    • Slide the light bulb circuit carefully back into the plastic slot.
  16. Bella Pro 90246 Light Bulb Replacement: 步骤 16 中的图像 1,2 Bella Pro 90246 Light Bulb Replacement: 步骤 16 中的图像 2,2
    • Plug your air fryer into an electrical outlet to confirm your new light bulb works.
    • Enjoy your perfectly cooked food!
结论
To reassemble your device follow this guide in reverse order starting with step 11.
2等其他人完成本指南。
Nattaly Vargas
于02/21/25注册
271 声望
撰写一个指南
团队
UC Davis, Team 1-5, Andersen Winter 2025 UC Davis, Team 1-5, Andersen Winter 2025 的会员
UCD-ANDERSEN-W25S1G5
3 名成员
创作了2篇指南
1指南评论
Can I please get a picture of the circuit board from both sides? I plugged this air fryer in 220 volts, which might've caused a couple resistors to go bad and I am trying to replace them, but I don't know the exact value of them
AbdulRaheem - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 87
总计 935
