跳转到主内容
Bella Linea CM1075T-ET Water Tube Valve Replacement
你所需要的
  1. Bella Linea CM1075T-ET  Water Tube Valve Replacement, Water Tube Valve: 步骤 1 中的图像 1,2 Bella Linea CM1075T-ET  Water Tube Valve Replacement, Water Tube Valve: 步骤 1 中的图像 2,2
    • Turn off the coffee maker by pressing the button labelled ON/OFF that is located on the top right of the front panel.
    • Make sure the light that is labelled ON is not illuminated before continuing to the next step.
    • Before brewing coffee, brew a pot of hot water to check for leaks from the water tubes and valve. If leaks occur, go back and check to make sure the hose clamps were reattached correctly.
  2. Bella Linea CM1075T-ET  Water Tube Valve Replacement: 步骤 2 中的图像 1,2 Bella Linea CM1075T-ET  Water Tube Valve Replacement: 步骤 2 中的图像 2,2
    • Unplug the coffee maker.
    • If the coffee maker was recently turned on before you unplugged it, the hotplate may still be hot. Wait for 30 minutes to an hour before proceeding to the next step, in order to let the hot plate cool.
  3. Bella Linea CM1075T-ET  Water Tube Valve Replacement: 步骤 3 中的图像 1,3 Bella Linea CM1075T-ET  Water Tube Valve Replacement: 步骤 3 中的图像 2,3 Bella Linea CM1075T-ET  Water Tube Valve Replacement: 步骤 3 中的图像 3,3
    • Set the coffee maker on its left side so the bottom is accessible.
    • Be sure to set the coffee maker on its left side, as this will make it easier for you to locate the water tube valve in later steps.
    • Rotate the coffee maker clockwise until the bottom panel is facing you.
  4. Bella Linea CM1075T-ET  Water Tube Valve Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #1 screwdriver to unscrew the four 3mm screws holding the bottom panel on.
  5. Bella Linea CM1075T-ET  Water Tube Valve Replacement: 步骤 5 中的图像 1,3 Bella Linea CM1075T-ET  Water Tube Valve Replacement: 步骤 5 中的图像 2,3 Bella Linea CM1075T-ET  Water Tube Valve Replacement: 步骤 5 中的图像 3,3
    • Remove the bottom panel by pulling it towards you using the square tabs located on the right side of the panel.
    • You may have to use more force than anticipated, and will hear a pop or snap when the panel opens.
  6. Bella Linea CM1075T-ET  Water Tube Valve Replacement: 步骤 6 中的图像 1,3 Bella Linea CM1075T-ET  Water Tube Valve Replacement: 步骤 6 中的图像 2,3 Bella Linea CM1075T-ET  Water Tube Valve Replacement: 步骤 6 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the two 3mm screws holding the curved metal tube in place.
  7. Bella Linea CM1075T-ET  Water Tube Valve Replacement: 步骤 7 中的图像 1,3 Bella Linea CM1075T-ET  Water Tube Valve Replacement: 步骤 7 中的图像 2,3 Bella Linea CM1075T-ET  Water Tube Valve Replacement: 步骤 7 中的图像 3,3
    • The water tube valve is the clear tube with parts inside of it, and is connected to the bottom of the curved metal tube. Be sure to remove this tube and not the clear tube that is hollow, which is connected to the top of the metal tube.
    • Use pliers to pinch and remove the clamp holding the water tube valve onto the metal tube.
    • Rotate the metal tube to the right so it is perpendicular to the bottom of the coffee maker.
    • Use pliers to pinch and remove the second clamp attaching the water tube valve to the connection of the water dispenser.
    • Be sure to reattach the hose clamps when reassembling. This reduces the potential risk of leaks.
  8. Bella Linea CM1075T-ET  Water Tube Valve Replacement: 步骤 8 中的图像 1,3 Bella Linea CM1075T-ET  Water Tube Valve Replacement: 步骤 8 中的图像 2,3 Bella Linea CM1075T-ET  Water Tube Valve Replacement: 步骤 8 中的图像 3,3
    • Detach the water tube valve from the metal tube.
    • Detach the water tube valve from the water dispenser connector.
    • Before attaching the new water tube valve, test which way the valve allows water to flow. Try blowing air into one end of the tube. The end that you were able to blow air through connects to the metal tube.
结论
After finishing the reassembly of your coffee maker, brew a pot of water to clean the new water tube valve and confirm that everything is working properly.
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 30
总计 1,134
