简介
This guide shows how to completely disassemble the Bella KitchenSmith 2 Slice Toaster 12082. Before beginning the disassembly, make sure that your toaster is not plugged into the wall - you don’t want to get electrocuted while you’re doing your disassembly. While you are doing the disassembly make sure to treat your toaster with respect - the toaster contains a circuit board which could be damaged if you are not careful.
你所需要的
Remove the toaster's handle by firmly grasping it and pulling on it away from the device.
2等其他人完成本指南。
