跳转到主内容
Bella 4-Slice Toaster Oven Glass Door Replacement
你所需要的
  1. Bella 4-Slice Toaster Oven Glass Door Replacement, Outer Shell: 步骤 1 中的图像 1,1
    • Remove five 11.6 mm Phillips #2 screws from the rear of the device.
  2. Bella 4-Slice Toaster Oven Glass Door Replacement: 步骤 2 中的图像 1,1
    • Open the front glass door of the toaster oven.
  3. Bella 4-Slice Toaster Oven Glass Door Replacement: 步骤 3 中的图像 1,1
    • Locate retaining screw on the upper-middle portion of the door frame.
  4. Bella 4-Slice Toaster Oven Glass Door Replacement: 步骤 4 中的图像 1,1
    • Remove one 21.9 mm Phillips #2 retaining screw from upper-middle portion of door frame.
  5. Bella 4-Slice Toaster Oven Glass Door Replacement: 步骤 5 中的图像 1,1
    • Flip toaster onto back panel with feet facing forward.
  6. Bella 4-Slice Toaster Oven Glass Door Replacement: 步骤 6 中的图像 1,1
    • Use spudger to pry the grey rubber inserts from the black plastic feet.
  7. Bella 4-Slice Toaster Oven Glass Door Replacement: 步骤 7 中的图像 1,1
    • Remove four 13.7mm Phillips #2 screws from black plastic feet to separate the cover from the device.
  8. Bella 4-Slice Toaster Oven Glass Door Replacement: 步骤 8 中的图像 1,1
    • Lift the black outer cover off of the toaster
  9. Bella 4-Slice Toaster Oven Glass Door Replacement, Glass Door: 步骤 9 中的图像 1,2 Bella 4-Slice Toaster Oven Glass Door Replacement, Glass Door: 步骤 9 中的图像 2,2
    • Unhook the black coil springs from back of the toaster on both sides of the device.
  10. Bella 4-Slice Toaster Oven Glass Door Replacement: 步骤 10 中的图像 1,1
    • Use the black spudger to gently depress the hinge prongs on the bottom of the door.
  11. Bella 4-Slice Toaster Oven Glass Door Replacement: 步骤 11 中的图像 1,2 Bella 4-Slice Toaster Oven Glass Door Replacement: 步骤 11 中的图像 2,2
    • Gently slide door away from the device, removing it from the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 878
