跳转到主内容
Bell and Howell DNV16HDZ LED Replacement
你所需要的
  1. Bell and Howell DNV16HDZ LED Replacement, Lens Assembly: 步骤 1 中的图像 1,2 Bell and Howell DNV16HDZ LED Replacement, Lens Assembly: 步骤 1 中的图像 2,2
    • Remove the five 30mm Phillips #0 screws on the bottom of the camera.
  2. Bell and Howell DNV16HDZ LED Replacement: 步骤 2 中的图像 1,1
    • Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Using a plastic opening tool is important since a metal one will scratch or damage the thin plastic hinges that hold the camera together.
  3. Bell and Howell DNV16HDZ LED Replacement: 步骤 3 中的图像 1,1
    • It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
  4. Bell and Howell DNV16HDZ LED Replacement, LED: 步骤 4 中的图像 1,1
    • Take out the two 20 mm Phillips #0 screws that attach it to the shutter.
  5. Bell and Howell DNV16HDZ LED Replacement: 步骤 5 中的图像 1,3 Bell and Howell DNV16HDZ LED Replacement: 步骤 5 中的图像 2,3 Bell and Howell DNV16HDZ LED Replacement: 步骤 5 中的图像 3,3
    • The two 30 mm Phillips #0 screws left can be removed to gain access to the circuit board along with the LED.
    • From here we can pop out the LED using the wedge or your fingers if you can manage it.
结论
Donald Desrosier
于03/11/16注册
101 声望
撰写一个指南
团队
UMass Dartmouth, Team 8-4, Botvin Spring 2016 UMass Dartmouth, Team 8-4, Botvin Spring 2016 的会员
UMASSD-BOTVIN-S16S8G4
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 317
