跳转到主内容
Bell and Howell DNV16HDZ Hand Strap Replacement
你所需要的
  1. Bell and Howell DNV16HDZ Hand Strap Replacement, Lens Assembly: 步骤 1 中的图像 1,2 Bell and Howell DNV16HDZ Hand Strap Replacement, Lens Assembly: 步骤 1 中的图像 2,2
    • Remove the five 30mm Phillips #0 screws on the bottom of the camera.
  2. Bell and Howell DNV16HDZ Hand Strap Replacement: 步骤 2 中的图像 1,1
    • Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Using a plastic opening tool is important since a metal one will scratch or damage the thin plastic hinges that hold the camera together.
  3. Bell and Howell DNV16HDZ Hand Strap Replacement: 步骤 3 中的图像 1,1
    • It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
  4. Bell and Howell DNV16HDZ Hand Strap Replacement, Hand Strap: 步骤 4 中的图像 1,2 Bell and Howell DNV16HDZ Hand Strap Replacement, Hand Strap: 步骤 4 中的图像 2,2
    • Pull the side with the hand strap upwards to disconnect it from the camcorder.
    • Unscrew the four 40 mm Phillips #0 screws.
    • Add the new hand strap now.
结论
Jerry Hadjah
于03/04/16注册
525 声望
创作了5篇指南
团队
UMass Dartmouth, Team 8-4, Botvin Spring 2016 UMass Dartmouth, Team 8-4, Botvin Spring 2016 的会员
UMASSD-BOTVIN-S16S8G4
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 18
总计 204
