跳转到主内容
Bell and Howell DNV16HDZ Front Lens Replacement
你所需要的
  1. Bell and Howell DNV16HDZ Front Lens Replacement, Lens Assembly: 步骤 1 中的图像 1,2 Bell and Howell DNV16HDZ Front Lens Replacement, Lens Assembly: 步骤 1 中的图像 2,2
    • Remove the five 30mm Phillips #0 screws on the bottom of the camera.
  2. Bell and Howell DNV16HDZ Front Lens Replacement: 步骤 2 中的图像 1,1
    • Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Using a plastic opening tool is important since a metal one will scratch or damage the thin plastic hinges that hold the camera together.
  3. Bell and Howell DNV16HDZ Front Lens Replacement: 步骤 3 中的图像 1,1
    • It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
  4. Bell and Howell DNV16HDZ Front Lens Replacement, Front Lens: 步骤 4 中的图像 1,1
    • Take out the two 20 mm screws that attach it to the shutter.
  5. Bell and Howell DNV16HDZ Front Lens Replacement: 步骤 5 中的图像 1,1
    • Remove the ten 30 mm Phillips #0 screws from the front lens.
  6. Bell and Howell DNV16HDZ Front Lens Replacement: 步骤 6 中的图像 1,1
    • Take the shutter screen parts out of the lens.
    • Now push out the front lens.
    • Slowly take out the shutter screen parts and lens, adding too much force will break them.
结论
Jerry Hadjah
于03/04/16注册
525 声望
创作了5篇指南
团队
UMass Dartmouth, Team 8-4, Botvin Spring 2016 UMass Dartmouth, Team 8-4, Botvin Spring 2016 的会员
UMASSD-BOTVIN-S16S8G4
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 9
总计 598
