跳转到主内容
Belkin NetCam HD Circuit Board Replacement
你所需要的
  1. Belkin NetCam HD Circuit Board Replacement, Case: 步骤 1 中的图像 1,1
    • Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
  2. Belkin NetCam HD Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Work a plastic opening tool into the seam and pry the face plate away from the back panel.
  3. Belkin NetCam HD Circuit Board Replacement: 步骤 3 中的图像 1,2 Belkin NetCam HD Circuit Board Replacement: 步骤 3 中的图像 2,2
    • Use pressure to separate the covers.
    • When pulling the device apart, separate from the bottom up in order to avoid pulling the wiring at the top apart.
  4. Belkin NetCam HD Circuit Board Replacement, Microphone: 步骤 4 中的图像 1,2 Belkin NetCam HD Circuit Board Replacement, Microphone: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to gently pull out the white attachment from the port.
    • Use your fingers to pull out the white attachment from the tan port on the front of the board a little.
  5. Belkin NetCam HD Circuit Board Replacement: 步骤 5 中的图像 1,2 Belkin NetCam HD Circuit Board Replacement: 步骤 5 中的图像 2,2
    • Use a pair of tweezers to wedge between the mic and the rubber guard to remove the mic from the front cover.
    • If the rubber guard comes off with the mic just remove the guard from mic and place back on the front cover.
  6. Belkin NetCam HD Circuit Board Replacement, Speaker: 步骤 6 中的图像 1,2 Belkin NetCam HD Circuit Board Replacement, Speaker: 步骤 6 中的图像 2,2
    • Use a Phillips #0 screwdriver to take out the two 1.2 mm screws on the board.
  7. Belkin NetCam HD Circuit Board Replacement: 步骤 7 中的图像 1,3 Belkin NetCam HD Circuit Board Replacement: 步骤 7 中的图像 2,3 Belkin NetCam HD Circuit Board Replacement: 步骤 7 中的图像 3,3
    • With your fingers, pull the circuit board out of the back casing.
    • When pulling the board up be sure to do so carefully so you do not break the cord which is attached on the back side.
  8. Belkin NetCam HD Circuit Board Replacement: 步骤 8 中的图像 1,2 Belkin NetCam HD Circuit Board Replacement: 步骤 8 中的图像 2,2
    • Gently pull the speaker out of the holder from the back of the cover.
  9. Belkin NetCam HD Circuit Board Replacement: 步骤 9 中的图像 1,1
    • The speaker wires are attached with the board. It can be unattached gently by pulling out the white attachment from the port.
  10. Belkin NetCam HD Circuit Board Replacement, Lens Piece: 步骤 10 中的图像 1,2 Belkin NetCam HD Circuit Board Replacement, Lens Piece: 步骤 10 中的图像 2,2
    • Flip the circuit board to the back side.
    • Fold down the tape with your finger.
    • With the Phillips #0 screwdriver, unscrew the two 1.2 mm screws.
  11. Belkin NetCam HD Circuit Board Replacement: 步骤 11 中的图像 1,2 Belkin NetCam HD Circuit Board Replacement: 步骤 11 中的图像 2,2
    • Flip the circuit board back to the other side.
    • Unscrew the screw with a Phillips #0 screw driver.
  12. Belkin NetCam HD Circuit Board Replacement: 步骤 12 中的图像 1,1
    • Slide the attached piece from the lens holder device.
  13. Belkin NetCam HD Circuit Board Replacement: 步骤 13 中的图像 1,2 Belkin NetCam HD Circuit Board Replacement: 步骤 13 中的图像 2,2
    在这个步骤中使用的工具:
    • Use the tweezers to pull the white attachment out from the port a little.
    • Then, take your fingers and gently pull the white attachment out from the tan port.
  14. Belkin NetCam HD Circuit Board Replacement, Switch Cover: 步骤 14 中的图像 1,2 Belkin NetCam HD Circuit Board Replacement, Switch Cover: 步骤 14 中的图像 2,2
    • On the back of the board pull the switch slowly upward to take it off.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 3-5, Sullivan Fall 2016 USF Tampa, Team 3-5, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S3G5
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 725
