跳转到主内容
Behringer Eurolive B212D Control PCB Replacement
你所需要的
  1. Behringer Eurolive B212D Control PCB Replacement, Removing the Behringer Eurolive B212D Electronics Box: 步骤 1 中的图像 1,1
    • CAUTION: Unplug your speaker from the power outlet.
    • Remove the 8 Phillips screws from the back of the speaker.
    Eurolive B212d back plate requirement
    Ashok Ahlawat - 回复
  2. Behringer Eurolive B212D Control PCB Replacement: 步骤 2 中的图像 1,1
    • Carefully remove the back panel, lifting out the metal electronics-box with it.
    • To avoid damaging your speaker, remove slowly, as there is still a wire attached from the electronics box to the speaker.
  3. Behringer Eurolive B212D Control PCB Replacement, Detach the Behringer Eurolive B212D Electronics Box: 步骤 3 中的图像 1,3 Behringer Eurolive B212D Control PCB Replacement, Detach the Behringer Eurolive B212D Electronics Box: 步骤 3 中的图像 2,3 Behringer Eurolive B212D Control PCB Replacement, Detach the Behringer Eurolive B212D Electronics Box: 步骤 3 中的图像 3,3
    • There are two silver, 6 mm-long machine screws with two 1/8" inner-diameter washers on the exterior of the metal electronics box; remove these first using a #2 philips screwdriver.
    • There are five of the same type of machine screw (silver, 6 mm-long) remaining around the metal electronics box's exterior; remove these as well.
    • You should have removed a total of 7 machine screws and 2 washers.
    • The reason for removing the two screws with the two washers first (or replacing them last when reassembling) is that their holes are actually slots. They are designed as slots to accommodate slop in the assembly, and if unscrewed out of order, you may have difficulty while removing - or possibly even damage - the other five screws.
  4. Behringer Eurolive B212D Control PCB Replacement: 步骤 4 中的图像 1,1
    • Remove the portion of the metal housing that you freed with the 7 screws in the previous step.
  5. Behringer Eurolive B212D Control PCB Replacement: 步骤 5 中的图像 1,3 Behringer Eurolive B212D Control PCB Replacement: 步骤 5 中的图像 2,3 Behringer Eurolive B212D Control PCB Replacement: 步骤 5 中的图像 3,3
    • Inside the metal electronics box housing is a white clip attached to a small PCB; remove this.
    • The white clip in this image has been glued, indicating that the manufacturer may not expect the end user to remove this clip; it is difficult to proceed with the disassembling without doing so, however, because the rest of the speaker does not provide a sufficient surface on which to work.
    • Snake the clip head through the hole in the metal electronics box casing.
  6. Behringer Eurolive B212D Control PCB Replacement, Disassembling Behringer Eurolive B212D Power & Control Panel: 步骤 6 中的图像 1,2 Behringer Eurolive B212D Control PCB Replacement, Disassembling Behringer Eurolive B212D Power & Control Panel: 步骤 6 中的图像 2,2
    • Remove the 4, 7/32" long machine screws with a #2 phillips head screwdriver.
  7. Behringer Eurolive B212D Control PCB Replacement: 步骤 7 中的图像 1,2 Behringer Eurolive B212D Control PCB Replacement: 步骤 7 中的图像 2,2
    • Caution: The circuit board contains many capacitors that could cause serious injury if touched. If possible, use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • Rotate the back panel so you can view the interior; note the three wires attached.
    • Remove the wires to you can fully remove the back panel.
  8. Behringer Eurolive B212D Control PCB Replacement, Control PCB: 步骤 8 中的图像 1,1
    • Remove the 4 indicated 9/32" long screws with the #1 phillips head screwdriver
  9. Behringer Eurolive B212D Control PCB Replacement: 步骤 9 中的图像 1,1
    • Remove the plastic cover.
  10. Behringer Eurolive B212D Control PCB Replacement: 步骤 10 中的图像 1,1
    • Remove all three of the knobs by pulling them straight up.
  11. Behringer Eurolive B212D Control PCB Replacement: 步骤 11 中的图像 1,1
    • Remove the 4 indicated 9/32" long screws using a #1 phillips head screwdriver.
  12. Behringer Eurolive B212D Control PCB Replacement: 步骤 12 中的图像 1,1
    • Remove the 2 indicated 3/16" long machine screws with a #1 phillips head screwdriver.
  13. Behringer Eurolive B212D Control PCB Replacement: 步骤 13 中的图像 1,1
    • The control PCB is free now, ready to be removed from the speaker's back panel.
结论
4等其他人完成本指南。
Troy W. Weber
于03/29/12注册
1,431 声望
创作了6篇指南
5条评论
In Step 3 there are 2 more screws, along the side of the 'electronics box’.
The washer and nut securing the 1/4” socket also need to be removed.
plasticmojo - 回复
Where do I find a replacement control PCB for my B212A??
jcard2002 - 回复
Hi,i like to conect the board to another amp pcb but i dont now wich cable is for what ,do you now where is the power and the inputs?i already look for schematics but i didnt find anything about..thanx
Manolis Travlos - 回复
Frank Hazzard - 回复
Hi
My Behringer Eurolive B215D speaker has got a serious hissing sound when I plug just the power with no audio player connected. Anyone with any idea what can course this? Thanks.
john raphoto - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 105
总计 10,170
