跳转到主内容
Beboncool Wireless Switch Pro Controller Buttons Replacement
你所需要的
  1. Beboncool Wireless Switch Pro Controller Buttons Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the seven 5 mm screws from the back of the controller.
  2. Beboncool Wireless Switch Pro Controller Buttons Replacement: 步骤 2 中的图像 1,2 Beboncool Wireless Switch Pro Controller Buttons Replacement: 步骤 2 中的图像 2,2
    • Gently separate the top and bottom halves of the controller.
  3. Beboncool Wireless Switch Pro Controller Buttons Replacement: 步骤 3 中的图像 1,2 Beboncool Wireless Switch Pro Controller Buttons Replacement: 步骤 3 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the two 5 mm screws holding the joystick motherboard in place.
  4. Beboncool Wireless Switch Pro Controller Buttons Replacement: 步骤 4 中的图像 1,1
    • Carefully move the bumper buttons out of the way.
  5. Beboncool Wireless Switch Pro Controller Buttons Replacement: 步骤 5 中的图像 1,2 Beboncool Wireless Switch Pro Controller Buttons Replacement: 步骤 5 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the 5 mm screw holding the motherboard in place.
    • Remove the motherboard.
  6. Beboncool Wireless Switch Pro Controller Buttons Replacement, Buttons: 步骤 6 中的图像 1,2 Beboncool Wireless Switch Pro Controller Buttons Replacement, Buttons: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • To remove the alphabetic buttons, remove the translucent silicone cover.
    • Use tweezers or your fingers to remove the buttons.
    • Pushing a button from below will elevate them enough to easily grab them.
  7. Beboncool Wireless Switch Pro Controller Buttons Replacement: 步骤 7 中的图像 1,2 Beboncool Wireless Switch Pro Controller Buttons Replacement: 步骤 7 中的图像 2,2
    • To remove the directional buttons, first remove the translucent silicone cover. Then, use tweezers or your fingers to remove the button pad.
    • As with the alphabetic buttons, push on the buttons from below, then grab them.
结论
Tayah Appel
于03/27/23注册
529 声望
创作了5篇指南
团队
Casper College, Team 1-3, Lareau Spring 2023 Casper College, Team 1-3, Lareau Spring 2023 的会员
CASC-LAREAU-S23S1G3
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 14
总计 198
