跳转到主内容
Beats Studio3 Micro USB-B Replacement
你所需要的
  1. Beats Studio3 Micro USB-B Replacement, Micro USB-B: 步骤 1 中的图像 1,3 Beats Studio3 Micro USB-B Replacement, Micro USB-B: 步骤 1 中的图像 2,3 Beats Studio3 Micro USB-B Replacement, Micro USB-B: 步骤 1 中的图像 3,3
    • Remove the pad that is on the charging port side using an opening tool.
  2. Beats Studio3 Micro USB-B Replacement: 步骤 2 中的图像 1,3 Beats Studio3 Micro USB-B Replacement: 步骤 2 中的图像 2,3 Beats Studio3 Micro USB-B Replacement: 步骤 2 中的图像 3,3
    • Remove seven screws from the earpiece using a Phillips screwdriver.
    • Pry the top panel away from the rest of the speaker using an opening tool.
    • There will still be wires attached, so be gentle.
  3. Beats Studio3 Micro USB-B Replacement: 步骤 3 中的图像 1,3 Beats Studio3 Micro USB-B Replacement: 步骤 3 中的图像 2,3 Beats Studio3 Micro USB-B Replacement: 步骤 3 中的图像 3,3
    • Use the soldering iron to carefully desolder five different wires from their respective points.
    • After disconnecting the wires, gently push the charger upward using your fingers to detach it from the base. Be careful to avoid damaging any components
    • Position the new charger by aligning it properly with the base. Push the new charger into place, ensuring it fits snugly and securely.
    • Reattach the five wires to their designated points on the new charger by soldering them securely. Ensure each wire is correctly connected to its corresponding point to guarantee proper functionality.
结论
另外一个人完成了本指南。
团队
CSU Los Angeles, Team 4-7, Kershman Fall 2023 CSU Los Angeles, Team 4-7, Kershman Fall 2023 的会员
CSULA-KERSHMAN-F23S4G7
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 75
总计 1,761
