跳转到主内容
Beats Studio First Generation Motherboard Replacement
你所需要的
  1. Beats Studio First Generation Motherboard Replacement, Removing the outer headband screws.: 步骤 1 中的图像 1,1
    • Using the T5 Torx screwdriver, remove the black screws on both sides of the outside of the headband.
    • 4 (2 per side) Torx type T5, 3.5mm long screws.
    not necessary !!
    John Coops - 回复
  2. Beats Studio First Generation Motherboard Replacement, Removing the plastic hinge guards.: 步骤 2 中的图像 1,2 Beats Studio First Generation Motherboard Replacement, Removing the plastic hinge guards.: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to gently pry the black plastic hinge piece directly away from the headband as shown.
    not necessary !!
    John Coops - 回复
    where can i find this piece?
    alex - 回复
  3. Beats Studio First Generation Motherboard Replacement, Removing the hinge pins.: 步骤 3 中的图像 1,1
    • Remove the small metal hinges from their housings. There are a total of 4 hinges, two per side of the headphones.
    • The hinge pins may slide out upon removal of the black hinge piece from the previous step. Be careful not to lose the hinge pins.
    i need to buy one hinge pin for my beats by dre 1.0 studio
    mrfuentescisneros - 回复
    This is DEFINITELY NOT necessary !
    John Coops - 回复
  4. Beats Studio First Generation Motherboard Replacement, Removing the metal bands.: 步骤 4 中的图像 1,1
    • Using a T5 Torx screwdriver, remove the silver screws from the silver segment of the headband.
    • 4 (2 per side) Torx type T5, 4.0mm long screws.
    This step is DEFINITELY NOT necessary !
    John Coops - 回复
  5. Beats Studio First Generation Motherboard Replacement, Removing the headband cushion.: 步骤 5 中的图像 1,3 Beats Studio First Generation Motherboard Replacement, Removing the headband cushion.: 步骤 5 中的图像 2,3 Beats Studio First Generation Motherboard Replacement, Removing the headband cushion.: 步骤 5 中的图像 3,3
    • Using the plastic opening tool, gently pry the headband cushion directly away from the plastic portion of the headband as shown. Pry the plastic portion a small amount and then move the opening tool sideways along on the headband. Repeat on both sides until the cushion separates from the top plastic part of the headband.
    John Coops - 回复
  6. Beats Studio First Generation Motherboard Replacement, Removing the metal headband support.: 步骤 6 中的图像 1,2 Beats Studio First Generation Motherboard Replacement, Removing the metal headband support.: 步骤 6 中的图像 2,2
    • Carefully remove the metal band from each of the hinge housings on each side. These should come off quite easily, provided that you have removed the hinges as instructed in step 3.
    • Congratulations, you have completely removed the headband! This will allow for ease of accessibility to the speakers should you choose to delve further into the depths of your headphones.
    • The black wire connecting the two speakers is somewhat fragile! Check that it isn't frayed. If it is frayed, consider repairing it with some electrical tape, splicing it, or replacing it.
    John Coops - 回复
  7. Beats Studio First Generation Motherboard Replacement, Removing the ear cushion.: 步骤 7 中的图像 1,3 Beats Studio First Generation Motherboard Replacement, Removing the ear cushion.: 步骤 7 中的图像 2,3 Beats Studio First Generation Motherboard Replacement, Removing the ear cushion.: 步骤 7 中的图像 3,3
    • Pinch the ear cushion between your thumb and forefinger.
    • Be very careful when pulling off the ear cushion, as the material holding the cushion onto the plastic ring can rip easily.
    • Carefully pull the cushion directly away from the earpiece.
    • The cushion will have a thin piece of foam inside of it that may fall out upon removal. Make sure to save this for reassembly.
    • Repeat for the other ear cushion.
    i have torn my cuson inside part that helps to hold the out soft part. and i lost it how to do it
    imbd Indian medicine bd - 回复
  8. Beats Studio First Generation Motherboard Replacement, Removing the plastic ring.: 步骤 8 中的图像 1,3 Beats Studio First Generation Motherboard Replacement, Removing the plastic ring.: 步骤 8 中的图像 2,3 Beats Studio First Generation Motherboard Replacement, Removing the plastic ring.: 步骤 8 中的图像 3,3
    • Use the plastic opening tool to remove the black ring from the speaker. This will allow you to access the screws on the metal ring.
    • Congratulations, you now have access to the rest of the speaker!
    • For reassembly, the black ring cannot snap back into the speaker the way it was disassembled. It must first go inside the black lip of the ear cushion. The black lip is located on the back side of the ear cushion. Please refer to the last two pictures on this step.
    • The black lip is located on the back side of the ear cushion.
    Hi does this work for the beats studio wireless?
    Jack - 回复
    I bought the parts two (2) ear cushions and a head band replacement on eBay for about $10 USD
    the process described here works well if the ear pad is old and you do not mind destroying the old one to gain access - however you will destroy the ear cushion pad assembly to separate it from the headphones - so be prepared to buy replacement cushion assemblies - when you disassemble you cannot re-install the original cushions
    the disassembly process tears the plastic cover that goes around the ear cushion plastic ring
    Legacy Finance Group - 回复
  9. Beats Studio First Generation Motherboard Replacement, Removing Metal Ring Earpiece: 步骤 9 中的图像 1,2 Beats Studio First Generation Motherboard Replacement, Removing Metal Ring Earpiece: 步骤 9 中的图像 2,2
    • Make sure you are working on the speaker that has the label "R" for the right ear. This speaker is the one you must disassemble in order to access the motherboard.
    • Use a 00 Phillips head screwdriver to remove the screws holding down the metal ring.
    • 7 Phillips type 00, 3.9mm long screws.
    • Set aside the metal ring.
  10. Beats Studio First Generation Motherboard Replacement, Removing the Drive (Speaker): 步骤 10 中的图像 1,1
    • Using the 0 Phillips head screwdriver, remove the 3 screws holding down the red speaker assembly.
    • 3 Phillips type 0, 8.0mm long screws.
  11. Beats Studio First Generation Motherboard Replacement, Remove Plastic Cover With Foam Top: 步骤 11 中的图像 1,2 Beats Studio First Generation Motherboard Replacement, Remove Plastic Cover With Foam Top: 步骤 11 中的图像 2,2
    • The screws removed in the previous step held the cover in place so, go ahead and just lift it out!
    • Easy as 1-2-3!
  12. Beats Studio First Generation Motherboard Replacement, Removing Motherboard and Cover: 步骤 12 中的图像 1,2 Beats Studio First Generation Motherboard Replacement, Removing Motherboard and Cover: 步骤 12 中的图像 2,2
    • Use the 0 Philips screwdriver to remove the two 6.0 mm screws screws that hold the motherboard and cover.
    • Place one hand on the other side ( where the beats logo is) so, that when you take the two screws out, the cover and motherboard don't fall out.
    • 2 Philips type 0, 6.0mm long screws.
  13. Beats Studio First Generation Motherboard Replacement, Remove Motherboard Cover: 步骤 13 中的图像 1,2 Beats Studio First Generation Motherboard Replacement, Remove Motherboard Cover: 步骤 13 中的图像 2,2
    • Once the screws have been removed from the other side, turn the speaker housing around.
    • Simply lift the cover with the beats logo off.
    • Congratulations! You have uncovered the motherboard!!
  14. Beats Studio First Generation Motherboard Replacement, Remove Power Button Cover: 步骤 14 中的图像 1,2 Beats Studio First Generation Motherboard Replacement, Remove Power Button Cover: 步骤 14 中的图像 2,2
    • Locate the black power button switch, then gently remove it with a pair of tweezers.
    • The mute button
    • Power switch.
  15. Beats Studio First Generation Motherboard Replacement, Remove Motherboard From Housing: 步骤 15 中的图像 1,1
    • Sometimes the motherboard will just fall out of its housing. If it doesn't, use a plastic opening tool to gently pry or push out.
  16. Beats Studio First Generation Motherboard Replacement, The Motherboard has Landed!: 步骤 16 中的图像 1,2 Beats Studio First Generation Motherboard Replacement, The Motherboard has Landed!: 步骤 16 中的图像 2,2
    • Congratulations, you now have access to the motherboard!
    • The wires can now be de-soldered and the old motherboard can be replaced with a new one.
    • Before you begin soldering, make sure to mark or label all of the wires so that you remember exactly where they go.
结论
12等其他人完成本指南。
Oscar
于04/15/14注册
1,130 声望
创作了2篇指南
团队
Cal Poly, Team 9-18, Regan Spring 2014 Cal Poly, Team 9-18, Regan Spring 2014 的会员
CPSU-REGAN-S14S9G18
4 名成员
创作了11篇指南
8条评论
Did you know what is the model or tipe of cable? I need to replace it
aaroncruzramirez - 回复
I would love to know as well what kind of cable I need to buy.
I mean the one that is multi colored there, very thin.
Arkymedes -
Where is the Bluetooth Adapter? Is it welded to the mother board? Or is it stand alone with like a flex cable connection? Basically, can the Bluetooth Adapter alone be replaced? Thanks.
Edwin Romero - 回复
There isn’t any Bluetooth. These are WIRED headphones, the model is named “Beats Studio” and these are the FIRST generation.
John Coops -
Do you do beats mixrs electrical wires replacements for the headphones ?
PS MY NAME IS JOEY WILSON and i and 17 teen years old and i was just couries if you can fix the replacement wires for my beats mixrs and they are white and the problems with them are one side works and the other side doesn't work and ut starts to get hot and gets overheat way to easy and they make weird noise so can you please helpme or even tell me what to do to fix my headphones so please send me a response ok thank have a great day .
Joey Wilson - 回复
I believe a revision needs to be made to this guide.
I have a Beats Studio headphone with a “v1.8” revision motherboard, and there is an additional wire in play. Look at the picture of the motherboard in step 14 of this guide. In the upper-right “corner” is one of the screw holes that holds the motherboard to the housing, and directly above it is a large round solder pad. On the v1.6 motherboard this pad is empty, but on the v1.8 motherboard there’s a single-conductor wire that goes from that pad to the very tip of the metal “spring band” that goes over your head while wearing the headphones. Yes, it’s soldered directly to that “spring band”. I suspect this is some kind of grounding wire.
Steve - 回复
Where can i buy the motherboard mine is damaged and i need to replace it
Moshie Samuel - 回复
Don't remove the ear pads in this manner, you'll most likely ruin them if you do it this way. The black plastic ring is designed to stay inside of the ear cup for disassembly and reassembly. Push against the clips towards the middle of the ear cup from the outside to release them 1 by 1. Just a word of advice, I now have to buy new pads because of this crappy guide.
Clayton Smith - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 45
总计 29,180
