跳转到主内容
Beats Studio First Generation Headphone Jack Replacement
你所需要的
  1. Beats Studio First Generation Headphone Jack Replacement, Removing the outer headband screws.: 步骤 1 中的图像 1,1
    • Using the T5 Torx screwdriver, remove the black screws on both sides of the outside of the headband.
    • 4 (2 per side) Torx type T5, 3.5mm long screws.
  2. Beats Studio First Generation Headphone Jack Replacement, Removing the plastic hinge guards.: 步骤 2 中的图像 1,2 Beats Studio First Generation Headphone Jack Replacement, Removing the plastic hinge guards.: 步骤 2 中的图像 2,2
    • Use the plastic opening tool to gently pry the black plastic hinge piece directly away from the headband as shown.
  3. Beats Studio First Generation Headphone Jack Replacement, Removing the hinge pins.: 步骤 3 中的图像 1,1
    • Remove the small metal hinges from their housings. There are a total of 4 hinges, two per side of the headphones.
    • The hinge pins may slide out upon removal of the black hinge piece from the previous step. Be careful not to lose the hinge pins.
  4. Beats Studio First Generation Headphone Jack Replacement, Removing the metal bands.: 步骤 4 中的图像 1,1
    • Using a T5 Torx screwdriver, remove the silver screws from the silver segment of the headband.
    • 4 (2 per side) Torx type T5, 4.0mm long screws.
  5. Beats Studio First Generation Headphone Jack Replacement, Removing the headband cushion.: 步骤 5 中的图像 1,3 Beats Studio First Generation Headphone Jack Replacement, Removing the headband cushion.: 步骤 5 中的图像 2,3 Beats Studio First Generation Headphone Jack Replacement, Removing the headband cushion.: 步骤 5 中的图像 3,3
    • Using the plastic opening tool, gently pry the headband cushion directly away from the plastic portion of the headband as shown. Pry the plastic portion a small amount and then move the opening tool sideways along on the headband. Repeat on both sides until the cushion separates from the top plastic part of the headband.
  6. Beats Studio First Generation Headphone Jack Replacement, Removing the metal headband support.: 步骤 6 中的图像 1,2 Beats Studio First Generation Headphone Jack Replacement, Removing the metal headband support.: 步骤 6 中的图像 2,2
    • Carefully remove the metal band from each of the hinge housings on each side. These should come off quite easily, provided that you have removed the hinges as instructed in step 3.
    • Congratulations, you have completely removed the headband! This will allow for ease of accessibility to the speakers should you choose to delve further into the depths of your headphones.
    • The black wire connecting the two speakers is somewhat fragile! Check that it isn't frayed. If it is frayed, consider repairing it with some electrical tape, splicing it, or replacing it.
  7. Beats Studio First Generation Headphone Jack Replacement, Removing the ear cushion.: 步骤 7 中的图像 1,3 Beats Studio First Generation Headphone Jack Replacement, Removing the ear cushion.: 步骤 7 中的图像 2,3 Beats Studio First Generation Headphone Jack Replacement, Removing the ear cushion.: 步骤 7 中的图像 3,3
    • Pinch the ear cushion between your thumb and forefinger.
    • Be very careful when pulling off the ear cushion, as the material holding the cushion onto the plastic ring can rip easily.
    • Carefully pull the cushion directly away from the earpiece.
    • The cushion will have a thin piece of foam inside of it that may fall out upon removal. Make sure to save this for reassembly.
    • Repeat for the other ear cushion.
  8. Beats Studio First Generation Headphone Jack Replacement, Removing the plastic ring.: 步骤 8 中的图像 1,3 Beats Studio First Generation Headphone Jack Replacement, Removing the plastic ring.: 步骤 8 中的图像 2,3 Beats Studio First Generation Headphone Jack Replacement, Removing the plastic ring.: 步骤 8 中的图像 3,3
    • Use the plastic opening tool to remove the black ring from the speaker. This will allow you to access the screws on the metal ring.
    • Congratulations, you now have access to the rest of the speaker!
    • For reassembly, the black ring cannot snap back into the speaker the way it was disassembled. It must first go inside the black lip of the ear cushion. The black lip is located on the back side of the ear cushion. Please refer to the last two pictures on this step.
    • The black lip is located on the back side of the ear cushion.
  9. Beats Studio First Generation Headphone Jack Replacement, Removing the metal ring.: 步骤 9 中的图像 1,1
    • Use a 00 Phillips head scewdriver to remove the screws holding down the metal ring.
    • Set aside the metal ring.
    • 7 Phillips type 00, 3.9mm long screws.
  10. Beats Studio First Generation Headphone Jack Replacement, Removing the speaker assembly.: 步骤 10 中的图像 1,1
    • Using the 0 Phillips head screwdriver, remove the 3 screws holding down the red speaker assembly.
    • 3 Phillips type 0, 8.0mm long screws.
  11. Beats Studio First Generation Headphone Jack Replacement, Remove the PCB screw.: 步骤 11 中的图像 1,1
    • Use the 00 screwdriver to remove the screw holding down the headphone jack PCB board.
    • 1 Phillips type 00, 5.0mm long screw.
  12. Beats Studio First Generation Headphone Jack Replacement, Removing the headphone jack assembly.: 步骤 12 中的图像 1,2 Beats Studio First Generation Headphone Jack Replacement, Removing the headphone jack assembly.: 步骤 12 中的图像 2,2
    • Use a plastic opening tool to gently pry the headphone jack and board up and out as shown.
    • Inspect the wires and ensure that they are all appropriately attached and not shorted or frayed.
    • If necessary, the board can be de-soldered and replaced with a new jack and board assembly.
结论
13等其他人完成本指南。
Garrett Reed
于04/15/14注册
1,628 声望
撰写一个指南
团队
Cal Poly, Team 9-18, Regan Spring 2014 Cal Poly, Team 9-18, Regan Spring 2014 的会员
CPSU-REGAN-S14S9G18
4 名成员
创作了13篇指南
11指南评论
Hi!
Could you please tell me where to get a replacement for the headphone jack (and board assembly)? I cannot find it anywhere.
Thanks a lot!!
Simon - 回复
These instructions are ridiculously over complicated! You can completely skip steps 1-6. You can also skip step 9 (no need to remove the metal ring). On my son's set the soldering job was sloppy and the wires had shorted causing the left side to stop working. I very gently lifted, separated, bent and repositioned the wires and it worked. But what you should actually do if you have ANY sense is to not buy this pile of overpriced plastic crap to begin with. My 30 yr old Sony MDR-V600's sound better, dont need batteries, and aren't falling apart.
alpinchisholm - 回复
Totally agreed. This person’s guides all show the unnecessary steps 1-6 and 9 which are definitely not needed.
John Coops -
Me gustaría que me proporcionarán el diagrama o como van conectados los cables ya que se me de soltaron y no se como van gracias
tripleseven13 - 回复
Where I can find pinouts for headphone jack and motherboard? I have 3 wires teared off the jack pcb.
And I have different wire colors. The one on top (step 12) is gold-red and yours is green.
Thanks.
A Sh - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 23
过去 30 天: 142
总计 32,256
