跳转到主内容
Beats Studio First Generation Ear Cushion Replacement
你所需要的
  1. Beats Studio First Generation Ear Cushion Replacement, Removing the ear cushion.: 步骤 1 中的图像 1,3 Beats Studio First Generation Ear Cushion Replacement, Removing the ear cushion.: 步骤 1 中的图像 2,3 Beats Studio First Generation Ear Cushion Replacement, Removing the ear cushion.: 步骤 1 中的图像 3,3
    • Pinch the ear cushion between your thumb and forefinger.
    • Be very careful when pulling off the ear cushion, as the material holding the cushion onto the plastic ring can rip easily.
    • Carefully pull the cushion directly away from the earpiece.
    • The cushion will have a thin piece of foam inside of it that may fall out upon removal. Make sure to save this for reassembly.
    • Repeat for the other ear cushion.
  2. Beats Studio First Generation Ear Cushion Replacement, Removing the plastic ring.: 步骤 2 中的图像 1,3 Beats Studio First Generation Ear Cushion Replacement, Removing the plastic ring.: 步骤 2 中的图像 2,3 Beats Studio First Generation Ear Cushion Replacement, Removing the plastic ring.: 步骤 2 中的图像 3,3
    • Use the plastic opening tool to remove the black ring from the speaker. This will allow you to access the screws on the metal ring.
    • Congratulations, you now have access to the rest of the speaker!
    • For reassembly, the black ring cannot snap back into the speaker the way it was disassembled. It must first go inside the black lip of the ear cushion. The black lip is located on the back side of the ear cushion. Please refer to the last two pictures on this step.
    • The black lip is located on the back side of the ear cushion.
终点
15等其他人完成本指南。
Anand Mangal
于04/15/14注册
1,082 声望
创作了2篇指南
团队
Cal Poly, Team 9-18, Regan Spring 2014 Cal Poly, Team 9-18, Regan Spring 2014 的会员
CPSU-REGAN-S14S9G18
4 名成员
创作了13篇指南
4指南评论
De nada me sirve saber cómo colocarlos si no sé donde conseguirlos... Ese debería ser el paso 1 del instructivo...
IGNACIO GREIFFENSTEIN - 回复
What if I break the black ring where do I get a replacement
Chris h - 回复
Hi - do you know where i can buy the replacement ear cushions for these particular headphones?
Jade ijeh - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 93
总计 63,957
