跳转到主内容
Beats Solo Pro Side panel Replacement
你所需要的
  1. Beats Solo Pro Side panel Replacement, Extending the Headphones: 步骤 1 中的图像 1,2 Beats Solo Pro Side panel Replacement, Extending the Headphones: 步骤 1 中的图像 2,2
    • Slide the headphones down to extend the hinge.
  2. Beats Solo Pro Side panel Replacement, Prying off the side panel: 步骤 2 中的图像 1,2 Beats Solo Pro Side panel Replacement, Prying off the side panel: 步骤 2 中的图像 2,2
    • Once extended insert a prying the new gap to unclip the panel
    • Once unclipped repeat on the other side of the panel
    • The two clips are towards the top of the panel, as indicated by the location of the metal prying tool in the image.
  3. Beats Solo Pro Side panel Replacement, Sliding out the side panel: 步骤 3 中的图像 1,2 Beats Solo Pro Side panel Replacement, Sliding out the side panel: 步骤 3 中的图像 2,2
    • Slide the panel down and lift away from the headphone just until its separated
    • Don't pull the plastic piece offs there is still cables attached to it
  4. Beats Solo Pro Side panel Replacement, Tightening or replacing: 步骤 4 中的图像 1,2 Beats Solo Pro Side panel Replacement, Tightening or replacing: 步骤 4 中的图像 2,2
    • If needed tighten the PH00 screw(if your side panel has came loose on it own you will need to do this to fix the issue)
    • If you want to replace the side panel you will need to carefully pry the cables out from where they are glued in and glue them in to the new panel(refer to second image)
结论
To reassemble complete steps in reverse:-)
4等其他人完成本指南。
HelloMacOS
于01/24/22注册
26,080 声望
创作了11篇指南
团队
Repair is War on Entropy Repair is War on Entropy 的会员
Community
26 名成员
创作了1,186篇指南
一条评论
Muchas gracias por tus pasos a seguir.
Yo tengo un problema pero con el tornillo que esta tapado por los cables, al cual no puedo acceder para poderlo apretar contra la tapa exterior.
Alfredo Olvera - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 18
过去 30 天: 112
总计 3,153
