跳转到主内容
Beats Solo HD Headband Replacement
你所需要的
  1. Beats Solo HD Headband Replacement, Headband: 步骤 1 中的图像 1,2 Beats Solo HD Headband Replacement, Headband: 步骤 1 中的图像 2,2
    • Unscrew both screws in the metal brace using a T4 Torx screwdriver.
    • Repeat all steps on both the right and left sides of the headphones.
  2. Beats Solo HD Headband Replacement: 步骤 2 中的图像 1,3 Beats Solo HD Headband Replacement: 步骤 2 中的图像 2,3 Beats Solo HD Headband Replacement: 步骤 2 中的图像 3,3
    • Lift away the metal brace and set it aside.
    • Be sure to keep the small plastic spacers located underneath the brace on either side. They may fall out when removing the brace.
  3. Beats Solo HD Headband Replacement: 步骤 3 中的图像 1,3 Beats Solo HD Headband Replacement: 步骤 3 中的图像 2,3 Beats Solo HD Headband Replacement: 步骤 3 中的图像 3,3
    • Pry off each clip on the headband cushion until it is loose enough to be removed.
    • Start by prying off the clips on either end, since they are easier to detach. Finish with the clips in the middle.
  4. Beats Solo HD Headband Replacement: 步骤 4 中的图像 1,3 Beats Solo HD Headband Replacement: 步骤 4 中的图像 2,3 Beats Solo HD Headband Replacement: 步骤 4 中的图像 3,3
    • Slide the gray plastic covering away from the hinge to remove it.
  5. Beats Solo HD Headband Replacement: 步骤 5 中的图像 1,1
    • Grasp the earpiece with one hand and bend the headphones at the hinge.
    • Brace the headband by pressing it downward against the surface you are working on.
    • These steps will prepare you to pry off the hinges, so make sure your hold on the headphones is stable.
  6. Beats Solo HD Headband Replacement: 步骤 6 中的图像 1,1
    • Slide the Jimmy between the metal earpiece and the plastic of the headband at the hinge.
  7. Beats Solo HD Headband Replacement: 步骤 7 中的图像 1,1
    • Pry the plastic away from the metal earpiece using an opening tool until one of the small cylindrical hinge pins can be removed.
    • This may be difficult, as prying takes some force. You may need to experiment and try whatever tools or prying techniques work best for you.
  8. Beats Solo HD Headband Replacement: 步骤 8 中的图像 1,3 Beats Solo HD Headband Replacement: 步骤 8 中的图像 2,3 Beats Solo HD Headband Replacement: 步骤 8 中的图像 3,3
    • Pull the earpiece out of the headband.
  9. Beats Solo HD Headband Replacement: 步骤 9 中的图像 1,2 Beats Solo HD Headband Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Remove the second hinge pin with precision tweezers and set it aside.
  10. Beats Solo HD Headband Replacement: 步骤 10 中的图像 1,2 Beats Solo HD Headband Replacement: 步骤 10 中的图像 2,2
    • Insert one of the hinge pins into one of the sockets of the new headband.
    • Press the hinge of the earpieces into the new headband by aligning it with the pin.
  11. Beats Solo HD Headband Replacement: 步骤 11 中的图像 1,3 Beats Solo HD Headband Replacement: 步骤 11 中的图像 2,3 Beats Solo HD Headband Replacement: 步骤 11 中的图像 3,3
    • Insert the second pin into the other socket of the headband using precision tweezers.
    • Squeeze the pin inwards if the hinge seems loose or if the pin is jutting out of the socket.
  12. Beats Solo HD Headband Replacement: 步骤 12 中的图像 1,3 Beats Solo HD Headband Replacement: 步骤 12 中的图像 2,3 Beats Solo HD Headband Replacement: 步骤 12 中的图像 3,3
    • Slide the gray plastic covers back onto the headband.
    • Pressing the white wire against the back of the headband can help to avoid damage during reassembly.
  13. Beats Solo HD Headband Replacement: 步骤 13 中的图像 1,3 Beats Solo HD Headband Replacement: 步骤 13 中的图像 2,3 Beats Solo HD Headband Replacement: 步骤 13 中的图像 3,3
    • Lay the metal brace in place.
    • If the small plastic spacers are loose, it may be helpful to place them down before the brace.
  14. Beats Solo HD Headband Replacement: 步骤 14 中的图像 1,2 Beats Solo HD Headband Replacement: 步骤 14 中的图像 2,2
    • Screw both screws back into the metal brace.
  15. Beats Solo HD Headband Replacement: 步骤 15 中的图像 1,3 Beats Solo HD Headband Replacement: 步骤 15 中的图像 2,3 Beats Solo HD Headband Replacement: 步骤 15 中的图像 3,3
    • Reattach the headband cushion by pressing each clip into place.
结论
When your replacement is finished, all parts other than the old headband should be reattached to the headphones. If needed, bend your headphones at the hinges to ensure they are properly attached. If there is some difficulty bending, the hinge pins may need to be pushed further in until they are secure. If the hinges on both sides bend without problem and all of the parts are reassembled, your replacement is done.
Erica Mota
于09/28/21注册
241 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 87
总计 1,909
