跳转到主内容
Beats Solo 3 Headband Replacement
你所需要的
  1. Beats Solo 3 Headband Replacement, Headband: 步骤 1 中的图像 1,3 Beats Solo 3 Headband Replacement, Headband: 步骤 1 中的图像 2,3 Beats Solo 3 Headband Replacement, Headband: 步骤 1 中的图像 3,3
    • Carefully partially remove the headband cushion cover. Be careful not to rip the two headband eyelets just above the screws on each end of the headband.
  2. Beats Solo 3 Headband Replacement: 步骤 2 中的图像 1,2 Beats Solo 3 Headband Replacement: 步骤 2 中的图像 2,2
    • With the main part of the cover off, pull the head band cover up and out of the metal headband ends, exposing the screws underneath.
  3. Beats Solo 3 Headband Replacement: 步骤 3 中的图像 1,3 Beats Solo 3 Headband Replacement: 步骤 3 中的图像 2,3 Beats Solo 3 Headband Replacement: 步骤 3 中的图像 3,3
    • Unscrew all four 1.4 mm screws on the right and left ends on the underside of the headband using a T5 Torx screwdriver.
  4. Beats Solo 3 Headband Replacement: 步骤 4 中的图像 1,1
    • Pull the metal headband end out from the headband slightly, and disconnect the rubber band from the hook.
  5. Beats Solo 3 Headband Replacement: 步骤 5 中的图像 1,2 Beats Solo 3 Headband Replacement: 步骤 5 中的图像 2,2
    • Remove the inner headband by gently prying the edges and corners.
  6. Beats Solo 3 Headband Replacement: 步骤 6 中的图像 1,1
    • Carefully peel up the glued wire in the headband.
  7. Beats Solo 3 Headband Replacement: 步骤 7 中的图像 1,1
    • Pull the headband out of the slots gently.
  8. Beats Solo 3 Headband Replacement: 步骤 8 中的图像 1,1
    • Put the new headband into the slots carefully.
结论
4等其他人完成本指南。
Joseph Konadu
于03/24/21注册
211 声望
撰写一个指南
团队
2条评论
help when i was putting on the new headband the snap on middle parts fell out and i cant put them back in (the metal connection parts)
koro - 回复
same it happen to me as well
Bardo -
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 38
过去 30 天: 251
总计 11,251
