跳转到主内容
Beats Solo 2 Wireless Power Button Replacement
你所需要的
  1. Beats Solo 2 Wireless Power Button Replacement, Power Button: 步骤 1 中的图像 1,3 Beats Solo 2 Wireless Power Button Replacement, Power Button: 步骤 1 中的图像 2,3 Beats Solo 2 Wireless Power Button Replacement, Power Button: 步骤 1 中的图像 3,3
    • Insert an opening pick in the seam between the right outer speaker casing and the speaker housing.
    • Slide the pick around the perimeter of the casing until the casing releases entirely from the speaker housing.
    • If you encounter any resistance, continue to pry along any spots where the seam is still close together.
    • Failure to loosen the seams may result in the piece breaking partially or completely during removal.
  2. Beats Solo 2 Wireless Power Button Replacement: 步骤 2 中的图像 1,2 Beats Solo 2 Wireless Power Button Replacement: 步骤 2 中的图像 2,2
    • Remove the right outer casing.
  3. Beats Solo 2 Wireless Power Button Replacement: 步骤 3 中的图像 1,3 Beats Solo 2 Wireless Power Button Replacement: 步骤 3 中的图像 2,3 Beats Solo 2 Wireless Power Button Replacement: 步骤 3 中的图像 3,3
    • Use a Phillips screwdriver to remove the 2.8 mm screw on the outer shell of the headphones.
  4. Beats Solo 2 Wireless Power Button Replacement: 步骤 4 中的图像 1,1
    • Remove the power button with your hand or a spudger by prying out the end that is still attached.
    • Beware of the sponge piece when putting the power button assembly back together.
结论
Victor Diuno
于04/02/24注册
130 声望
撰写一个指南
团队
IUPUI, Team 2-1, Harley Spring 2024 IUPUI, Team 2-1, Harley Spring 2024 的会员
IUPUI-HARLEY-S24S2G1
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 26
总计 107
