跳转到主内容
Beats Solo 2 Wireless Motherboard Replacement
你所需要的
  1. Beats Solo 2 Wireless Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 Beats Solo 2 Wireless Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 Beats Solo 2 Wireless Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Insert an opening pick in the seam between the left outer speaker casing and the speaker housing.
    • Slide the pick around the perimeter of the casing until the outer casing releases entirely from the speaker housing.
    • Failure to loosen the seams may result in the piece breaking partially or completely when removing.
  2. Beats Solo 2 Wireless Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the right outer casing with your hand.
  3. Beats Solo 2 Wireless Motherboard Replacement: 步骤 3 中的图像 1,1
    • Use tweezers to remove the tape from the motherboard.
    • Loosen the wires from the casing with tweezers.
    • The wires attached to the shell are pinched together in a piece of plastic that will be difficult to remove
  4. Beats Solo 2 Wireless Motherboard Replacement: 步骤 4 中的图像 1,2 Beats Solo 2 Wireless Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips screwdriver to remove all four of the 4.25 mm screw that secure the motherboard.
  5. Beats Solo 2 Wireless Motherboard Replacement: 步骤 5 中的图像 1,2 Beats Solo 2 Wireless Motherboard Replacement: 步骤 5 中的图像 2,2
    • Disconnect all of the motherboard connectors.
    • Do not pull on the wires.
  6. Beats Solo 2 Wireless Motherboard Replacement: 步骤 6 中的图像 1,1
    • Lift the motherboard up and out of the housing.
结论
另外一个人完成了本指南。
Cooper Truong
于04/02/24注册
277 声望
创作了2篇指南
团队
IUPUI, Team 2-1, Harley Spring 2024 IUPUI, Team 2-1, Harley Spring 2024 的会员
IUPUI-HARLEY-S24S2G1
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 15
总计 83
