跳转到主内容
Beats Solo 2 Wireless Earpads Replacement
你所需要的
  1. Beats Solo 2 Wireless Earpads Replacement, Earpads: 步骤 1 中的图像 1,3 Beats Solo 2 Wireless Earpads Replacement, Earpads: 步骤 1 中的图像 2,3 Beats Solo 2 Wireless Earpads Replacement, Earpads: 步骤 1 中的图像 3,3
    • Set the headphones down on a flat surface.
    • Insert a plastic card or opening pick between between the earpads and the speaker housing.
    • Carefully pry around the entire perimeter of the the pads until they fully release.
  2. Beats Solo 2 Wireless Earpads Replacement: 步骤 2 中的图像 1,1
    • Use the card to clean up the adhesive residue left on the headphones.
    • Apply high-concentration isopropyl alcohol to a cloth and use it to remove any lingering adhesive.
  3. Beats Solo 2 Wireless Earpads Replacement: 步骤 3 中的图像 1,1
    • Fold the other side of the headphones you are not working on.
    • This makes it easier to work and focus on the side you are on.
    • Carefully pick up the new pads and line them up with the Beats.
    • The new earpads come with the adhesive on them already; you just have to peel the plastic covering off.
  4. Beats Solo 2 Wireless Earpads Replacement: 步骤 4 中的图像 1,1
    • Press down on the new pad to make sure it adheres to the headphones.
    • Make sure to go around the pad and press down on every part.
  5. Beats Solo 2 Wireless Earpads Replacement: 步骤 5 中的图像 1,1
    • Find a large object and place the headphones on it just like the object is wearing the headphones.
    • Leave the headphones on the object for an hour so it can clamp the earpads to itself.
    • After 1 hour, you are good to go.
终点
另外一个人完成了本指南。
Ayotunde Dada
于01/11/24注册
151 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 36
总计 110
