简介
If your Beats Wireless Solo 2 Headphones do not feel comfortable on your ears while wearing them, this means the earpads are coming off, or the material covering the foam on the earpads is ripped. It might be time to consider changing the earpads. Use this guide to replace the earpads on your Beats.
The earpads are the most important part of the headphones when it comes to comfort. If you have bad earpads, your ears may hurt from the discomfort caused by the headphones, or you might just not want to wear the headphones in public because the earpads are ripped and look ugly.
Before using this guide, you will need to have your replacement earpads ready to go.
Before beginning, make sure to power off your headphones and disconnect from any external power source.
你所需要的
Set the headphones down on a flat surface.
Insert a plastic card or opening pick between between the earpads and the speaker housing.
Carefully pry around the entire perimeter of the the pads until they fully release.
另外一个人完成了本指南。
