跳转到主内容
Beats Solo 2 Wireless Battery Replacement
你所需要的
  1. Beats Solo 2 Wireless Battery Replacement, Battery: 步骤 1 中的图像 1,3 Beats Solo 2 Wireless Battery Replacement, Battery: 步骤 1 中的图像 2,3 Beats Solo 2 Wireless Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Insert an opening pick in the seam between the right outer speaker casing and the speaker housing.
    • Slide the pick around the perimeter of the casing until the casing releases entirely from the speaker housing.
    • Failure to loosen the seams may result in the piece breaking partially or completely during removal.
  2. Beats Solo 2 Wireless Battery Replacement: 步骤 2 中的图像 1,3 Beats Solo 2 Wireless Battery Replacement: 步骤 2 中的图像 2,3 Beats Solo 2 Wireless Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the right outer speaker casing.
  3. Beats Solo 2 Wireless Battery Replacement: 步骤 3 中的图像 1,3 Beats Solo 2 Wireless Battery Replacement: 步骤 3 中的图像 2,3 Beats Solo 2 Wireless Battery Replacement: 步骤 3 中的图像 3,3
    • Use tweezers to disconnect the battery connector from the circuit board.
    • Do not pull on the wires.
  4. Beats Solo 2 Wireless Battery Replacement: 步骤 4 中的图像 1,3 Beats Solo 2 Wireless Battery Replacement: 步骤 4 中的图像 2,3 Beats Solo 2 Wireless Battery Replacement: 步骤 4 中的图像 3,3
    • Use an opening pick to gently pry up the battery.
    • The battery is secured in the housing with adhesive. You can apply some high-concentration alcohol beneath the battery to help loosen the adhesive.
    • Avoid bending or puncturing the battery.
  5. Beats Solo 2 Wireless Battery Replacement: 步骤 5 中的图像 1,1
    • Lift the battery up and out of the chassis.
结论
另外一个人完成了本指南。
Cooper Truong
于04/02/24注册
277 声望
创作了2篇指南
团队
IUPUI, Team 2-1, Harley Spring 2024 IUPUI, Team 2-1, Harley Spring 2024 的会员
IUPUI-HARLEY-S24S2G1
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 32
总计 103
