跳转到主内容
Beats Mixr Headband Replacement
你所需要的
  1. Beats Mixr Headband Replacement, Remove the caps on the headband: 步骤 1 中的图像 1,1
    • Use a spudger or prying tool to remove the cap on both sides of the headband by applying pressure where the cap meets the band. Next, you will need a Phillips head #00 screwdriver to remove the screws and washer. Twist the screwdriver into the screw and pull it apart from the washer when it becomes loose.
  2. Beats Mixr Headband Replacement, Separate the ear cuff from the headband.: 步骤 2 中的图像 1,1
    • Begin by pulling the two parts of the headband away from each other slowly and make sure not to break any wires. The wires will now slide free of the headband.
结论
29等其他人完成本指南。
Allie Horton
于10/08/14注册
929 声望
撰写一个指南
团队
USF Tampa, Team 1-11, Donnelly Fall 2014 USF Tampa, Team 1-11, Donnelly Fall 2014 的会员
USFT-DONNELLY-F14S1G11
1 名成员
创作了3篇指南
3条评论
Started to disassemble my Mixr. After removing the covers I found the screws not so easy to remove as stated. For one, they must have used lock tite. In addition the nut and screw are so tight a screw driver will not work. Mine has spanner type nuts. I need to find a wrench that will fit.
Has anyone ran into this.
Robert Schumann - 回复
Did you figure out how to get the screws out without breaking?
simmons4jesus -
The replacement parts listed are for studio not mixr and the colors dont match!
Missy Truth - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 32
总计 14,401
