跳转到主内容
Beaded Bracelet Clasp Replacement
你所需要的
  1. Beaded Bracelet Clasp Replacement, Beaded Bracelet Clasp: 步骤 1 中的图像 1,1
    • From the left end of the bracelet, string on a crimp bead and one end of the new clasp.
    • Bring the clasp and crimp bead 3 inches from the left end of the string.
  2. Beaded Bracelet Clasp Replacement: 步骤 2 中的图像 1,1
    • Loop the left end of the string through the left side of the crimp bead.
  3. Beaded Bracelet Clasp Replacement: 步骤 3 中的图像 1,1
    • Push the crimp bead up close to the clasp.
    • Push the crimp bead up as close as you can to the clasp.
  4. Beaded Bracelet Clasp Replacement: 步骤 4 中的图像 1,2 Beaded Bracelet Clasp Replacement: 步骤 4 中的图像 2,2
    • Use the bead crimp tool to squeeze the crimp bead shut.
    • Use scissors to cut off excess string.
  5. Beaded Bracelet Clasp Replacement: 步骤 5 中的图像 1,1
    • Bead the bracelet from the right end.
  6. Beaded Bracelet Clasp Replacement: 步骤 6 中的图像 1,1
    • After all beads are on, string on a crimp bead and then the other end of the new clasp.
  7. Beaded Bracelet Clasp Replacement: 步骤 7 中的图像 1,1
    • Loop the right end of the string through the right side of the crimp bead.
  8. Beaded Bracelet Clasp Replacement: 步骤 8 中的图像 1,1
    • Pull on the string to tighten the bracelet.
    • You do not want the beads spread out.
  9. Beaded Bracelet Clasp Replacement: 步骤 9 中的图像 1,2 Beaded Bracelet Clasp Replacement: 步骤 9 中的图像 2,2
结论
2等其他人完成本指南。
Kelly
于03/22/16注册
182 声望
撰写一个指南
团队
Michigan Tech, Team 1-17, Lauer Spring 2016 Michigan Tech, Team 1-17, Lauer Spring 2016 的会员
MTU-LAUER-S16S1G17
1 名成员
创作了1篇指南
2条评论
Awesome!! Its very beautiful [|bracelets] each step make this bracelets so easy. Thank you!! Keep it up
daniel - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 41
总计 2,392
