跳转到主内容
加入维修社区 - 创建账户
Bazic 3003 Battery Replacement
你所需要的
  1. Bazic 3003 Battery Replacement, Bazic Calculator: 步骤 1 中的图像 1,1
    • Press the "OFF" button on your Bazic 3003 calculator.
    • Make sure it is powered off before you begin the repair.
  2. Bazic 3003 Battery Replacement: 步骤 2 中的图像 1,1
    • Turn your calculator over so the back is facing up.
  3. Bazic 3003 Battery Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the 1.0 mm screw from the battery compartment.
  4. Bazic 3003 Battery Replacement: 步骤 4 中的图像 1,1
    • Only one button battery is needed for the calculator to function but you can add one or two.
    • Use your fingers or a plastic spudger to remove the battery from the calculator.
    • Insert the new button battery into the slot and push it into place.
  5. Bazic 3003 Battery Replacement: 步骤 5 中的图像 1,1
    • Replace the battery door.
    • Use a Phillips #0 screwdriver to replace the screw and secure the battery door.
  6. Bazic 3003 Battery Replacement: 步骤 6 中的图像 1,1
    • Push the "On" button on your calculator and check if the buttons work and function properly.
结论
Bryan Reyes
于03/04/25注册
133 声望
撰写一个指南
团队
CSU Los Angeles, Team 3-3, Grodsky Spring 2025 CSU Los Angeles, Team 3-3, Grodsky Spring 2025 的会员
CSULA-GRODSKY-S25S3G3
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 9
过去 30 天: 34
总计 266
