跳转到主内容
Battery Replacement on an Asus Q524U
你所需要的
  1. Battery Replacement on an Asus Q524U, Remove back plate of computer: 步骤 1 中的图像 1,3 Battery Replacement on an Asus Q524U, Remove back plate of computer: 步骤 1 中的图像 2,3 Battery Replacement on an Asus Q524U, Remove back plate of computer: 步骤 1 中的图像 3,3
    • Remove all 10 screws from the backplate of the computer using a Torx T5 screwdriver.
    • Make sure to keep all screws in a safe place, they are small and it is very easy to lose track of them.
  2. Battery Replacement on an Asus Q524U, Use prying tool to help separate back plate: 步骤 2 中的图像 1,2 Battery Replacement on an Asus Q524U, Use prying tool to help separate back plate: 步骤 2 中的图像 2,2
    • Use the prying tool to help maneuver and separate the back plate off of the computer safely. This will expose important hardware and internal parts.
  3. Battery Replacement on an Asus Q524U, Remove the silver bridge restricting the battery by lifting tabs: 步骤 3 中的图像 1,1
    • Pull lightly on the blue tabs until the silver bridge is safely free.
    • Once the bridge is removed the battery is then accessible.
  4. Battery Replacement on an Asus Q524U, Remove screws from battery bracket: 步骤 4 中的图像 1,1
    • Get a #00 Philips head screwdriver ready for use.
    • Carefully remove the #00 Philips screws to release the battery from the computer.
  5. Battery Replacement on an Asus Q524U, Disconnect battery from circuit board: 步骤 5 中的图像 1,1
    • Locate the connector for the computer battery and circuit board.
    • Carefully pull up on the connection to safely disconnect the battery.
  6. Battery Replacement on an Asus Q524U, Replace battery and reassemble computer: 步骤 6 中的图像 1,1
    • Carefully replace with a new battery and reassemble the computer with all previously used screws.
结论
Furthermore, this is a comprehensive guide for a battery replacement on an Asus Q524U personal computer. To reassemble your device, please follow these instructions in reverse order.
3等其他人完成本指南。
Zachary Franz
于01/27/19注册
214 声望
撰写一个指南
3条评论
Thanks.
How long a battery should last?
And how long daily without charging?
I'm sorry but i have never had a laptop in my life.
I'll appreciate your help.
Andrea Redeker - 回复
Hello I want to ask. I’m trying to replace the battery and im at the part with the blue strip for the Silver bridge part is out how do I put it back on?
Devon Jones - 回复
How did you determine you had to replace the battery. My green charging light won’t turn on and I’ve replaced the charger, but still nothing. Could this be due to a bad battery?
dwkestell - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 21
过去 30 天: 72
总计 4,393
