跳转到主内容
加入维修社区 - 创建账户
Battery Disconnect
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Battery Disconnect, Prepare your laptop for disassembly: 步骤 1 中的图像 1,2 Battery Disconnect, Prepare your laptop for disassembly: 步骤 1 中的图像 2,2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Battery Disconnect, Unfasten the back cover: 步骤 2 中的图像 1,2 Battery Disconnect, Unfasten the back cover: 步骤 2 中的图像 2,2
    • Use a Phillips screwdriver to remove the ten screws securing the back cover:
    • Six 7.6 mm-long screws
    • Four 4.7 mm-long screws
  3. Battery Disconnect, Insert an opening pick: 步骤 3 中的图像 1,3 Battery Disconnect, Insert an opening pick: 步骤 3 中的图像 2,3 Battery Disconnect, Insert an opening pick: 步骤 3 中的图像 3,3
    • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release.
    • Insert the flat side of an opening pick between the top left corner of the back cover and frame.
    • Angle the pick down to about 45 degrees.
  4. Battery Disconnect, Release the left clips: 步骤 4 中的图像 1,3 Battery Disconnect, Release the left clips: 步骤 4 中的图像 2,3 Battery Disconnect, Release the left clips: 步骤 4 中的图像 3,3
    • Keep the opening pick angled down at about 45 degrees while sliding it along the front and side edges to help release the clips.
    • Slide the pick to the bottom left corner of the laptop to release the left clips.
  5. Battery Disconnect, Release the bottom clips: 步骤 5 中的图像 1,3 Battery Disconnect, Release the bottom clips: 步骤 5 中的图像 2,3 Battery Disconnect, Release the bottom clips: 步骤 5 中的图像 3,3
    • Slide the opening pick to the bottom right corner to release the bottom clips.
  6. Battery Disconnect, Release the right clips: 步骤 6 中的图像 1,3 Battery Disconnect, Release the right clips: 步骤 6 中的图像 2,3 Battery Disconnect, Release the right clips: 步骤 6 中的图像 3,3
    • Slide the opening pick to the top right corner to release the right clips.
  7. Battery Disconnect, Insert an opening pick: 步骤 7 中的图像 1,2 Battery Disconnect, Insert an opening pick: 步骤 7 中的图像 2,2
    • Insert the flat end of an opening pick between the back cover and frame, to the left of the right hinge.
    • Pry the back cover up with the pick to release the top right clips.
    • Leave the pick inserted next to the right hinge.
  8. Battery Disconnect, Release the top clips: 步骤 8 中的图像 1,3 Battery Disconnect, Release the top clips: 步骤 8 中的图像 2,3 Battery Disconnect, Release the top clips: 步骤 8 中的图像 3,3
    • Angle the pick up to about 45 degrees.
    • Slide the opening pick to the top left corner to release the remaining clips.
  9. Battery Disconnect, Remove the back cover: 步骤 9 中的图像 1,3 Battery Disconnect, Remove the back cover: 步骤 9 中的图像 2,3 Battery Disconnect, Remove the back cover: 步骤 9 中的图像 3,3
    • Remove the back cover.
    • During reassembly, lay the back cover on the frame and press firmly around the perimeter to engage all the clips.
  10. Battery Disconnect, Disconnect the battery: 步骤 10 中的图像 1,3 Battery Disconnect, Disconnect the battery: 步骤 10 中的图像 2,3 Battery Disconnect, Disconnect the battery: 步骤 10 中的图像 3,3
    • Use the flat end of a spudger to gently push the battery connector out of its socket on the motherboard.
结论
Spencer Day
于09/14/22注册
163,286 声望
创作了1,043篇指南
团队
iFixit iFixit 的会员
Staff
124 名成员
创作了24,235篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 28
