跳转到主内容
加入维修社区 - 创建账户
Battery Disconnect
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Battery Disconnect, Unfasten the lower case: 步骤 1 中的图像 1,2 Battery Disconnect, Unfasten the lower case: 步骤 1 中的图像 2,2
    • Use a Phillips screwdriver to remove the 10 screws securing the lower case:
    • Six 12 mm screws
    • Four 4.5 mm screws
  2. Battery Disconnect, Insert an opening pick: 步骤 2 中的图像 1,2 Battery Disconnect, Insert an opening pick: 步骤 2 中的图像 2,2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Battery Disconnect, Release the clips: 步骤 3 中的图像 1,3 Battery Disconnect, Release the clips: 步骤 3 中的图像 2,3 Battery Disconnect, Release the clips: 步骤 3 中的图像 3,3
    • Slide the pick along the front edge to release the clips securing the lower case.
    • Continue sliding the opening pick along the left and right edges to release the remaining clips.
  4. Battery Disconnect, Remove the lower case: 步骤 4 中的图像 1,3 Battery Disconnect, Remove the lower case: 步骤 4 中的图像 2,3 Battery Disconnect, Remove the lower case: 步骤 4 中的图像 3,3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  5. Battery Disconnect, Disconnect the battery: 步骤 5 中的图像 1,3 Battery Disconnect, Disconnect the battery: 步骤 5 中的图像 2,3 Battery Disconnect, Disconnect the battery: 步骤 5 中的图像 3,3
    • Use the pointed end of a spudger to push each side of the battery connector until it comes out of the socket.
结论
Spencer Day
于09/14/22注册
156,764 声望
创作了1,033篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,877篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 49
