跳转到主内容
加入维修社区 - 创建账户
Battery Disconnect
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Battery Disconnect, Unfasten the lower case: 步骤 1 中的图像 1,3 Battery Disconnect, Unfasten the lower case: 步骤 1 中的图像 2,3 Battery Disconnect, Unfasten the lower case: 步骤 1 中的图像 3,3
    • Remove the 14 Phillips screws securing the lower case:
    • Seven 8.8 mm screws
    • Seven 10.1 mm screws
    • Use a Phillips screwdriver to loosen the captive screw.
    • Loosening this captive screw will pop up and separate the bottom-right corner of the back cover from the chassis.
    • During reassembly, tighten the captive screw before the rest of the screws.
  2. Battery Disconnect, Insert an opening pick: 步骤 2 中的图像 1,2 Battery Disconnect, Insert an opening pick: 步骤 2 中的图像 2,2
    • Insert an opening pick between the lower case and the chassis on the front right edge near the captive screw.
  3. Battery Disconnect, Release the clips: 步骤 3 中的图像 1,3 Battery Disconnect, Release the clips: 步骤 3 中的图像 2,3 Battery Disconnect, Release the clips: 步骤 3 中的图像 3,3
    • Slide the pick along the front edge to release the clips securing the lower case.
    • Repeat this process along the perimeter of the lower case to release the remaining clips.
  4. Battery Disconnect, Remove the lower case: 步骤 4 中的图像 1,3 Battery Disconnect, Remove the lower case: 步骤 4 中的图像 2,3 Battery Disconnect, Remove the lower case: 步骤 4 中的图像 3,3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  5. Battery Disconnect, Reposition the tape: 步骤 5 中的图像 1,2 Battery Disconnect, Reposition the tape: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers or your fingers to peel back the tape on the battery connector.
  6. Battery Disconnect, Disconnect the locking bar: 步骤 6 中的图像 1,2 Battery Disconnect, Disconnect the locking bar: 步骤 6 中的图像 2,2
    • Use the flat end of a spudger to gently push the locking bar away from the battery connector.
    • Make sure the locking bar is not covering the battery connector, or you may damage the battery connector's socket in the next step.
  7. Battery Disconnect, Disconnect the battery: 步骤 7 中的图像 1,3 Battery Disconnect, Disconnect the battery: 步骤 7 中的图像 2,3 Battery Disconnect, Disconnect the battery: 步骤 7 中的图像 3,3
    • Insert the pointed end of a spudger under the battery connector.
    • Pry under the left edge of the battery connector to disconnect the left side of the connector.
    • Repeat this procedure for the right side of the connector.
结论
Spencer Day
于09/14/22注册
159,841 声望
创作了1,045篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,978篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 64
