跳转到主内容
加入维修社区 - 创建账户
Batteries in Nikon Coolpix 4600 Replacement
你所需要的
  1. Batteries in Nikon Coolpix 4600 Replacement, Batteries: 步骤 1 中的图像 1,1
    • Locate the battery compartment on the bottom right of the camera.
  2. Batteries in Nikon Coolpix 4600 Replacement: 步骤 2 中的图像 1,2 Batteries in Nikon Coolpix 4600 Replacement: 步骤 2 中的图像 2,2
    • While holding the camera with the lens facing toward you, slide the lock button to the right and pull the battery door towards you. The battery door should pop open.
    • If the door does not pop open, gently lift the door using your finger.
  3. Batteries in Nikon Coolpix 4600 Replacement: 步骤 3 中的图像 1,1
    • Remove the dead batteries. The easiest way to do this is by turning the camera right side up and gently tapping the lens side of the camera against your hand until they fall out. If this does not work, you can simply pull them out.
  4. Batteries in Nikon Coolpix 4600 Replacement: 步骤 4 中的图像 1,1
    • Insert fresh AA batteries into the compartment as demonstrated in the picture to the left. The orientation of the batteries is important to ensure the camera works properly.
    • Close the battery door.
    • Remember to slide the switch back into the lock position.
结论
Reassembly of the camera is the final step in the guide.
Richard
于04/19/12注册
9 声望
撰写一个指南
团队
Cal Poly, Team 9-43, Regan Spring 2012 Cal Poly, Team 9-43, Regan Spring 2012 的会员
CPSU-REGAN-S12S9G43
5 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 47
总计 4,097
