简介
Improper installation of a new spout could cause new leaks, damaged piping, or cause damage to your nice looking spout. If you need to replace a damaged or non working bathtub spout diverter, this guide will offer step by step instructions with visuals to help you . Replace your spout with confidence knowing that such details are highlighted in this guide.
你所需要的
Adjust your pipe wrench so that it fits over the rag and is snug against the bathtub spout.
Check the underside of the spout next to the wall and look for a hole or screw hidden under the spout.
Once found, loosen the screw with an Allen wrench (but do not remove) the set screw.
Gently turn the wrench counterclockwise (to the left) until it is loose enough to twist with your hands.
Once complete, the bathtub spout should be fitted to the wall and should produce a steady flow of water.
4等其他人完成本指南。
