跳转到主内容
Base enclosure disassembly
你所需要的
  1. Base enclosure disassembly, Remove the battery: 步骤 1 中的图像 1,3 Base enclosure disassembly, Remove the battery: 步骤 1 中的图像 2,3 Base enclosure disassembly, Remove the battery: 步骤 1 中的图像 3,3
    • Turn the laptop upside down and gently lay it down on a flat surface.
    • Slide the battery release latch to the right and the battery will pop up slightly.
    • While keeping the latch slid with one hand, grab the battery with the other hand and remove it by pivoting it upward.
    • At this point some users would turn the laptop upside down once again and press the power button a couple of times. They say that this should help dissipating all of the remaining electricity around the device. Up to you :)
  2. Base enclosure disassembly, Remove the captive screw of the service door: 步骤 2 中的图像 1,1
    • Remove the Phillips PM2.0×4.0 screw using a PH#00 screwdriver.
  3. Base enclosure disassembly, Remove the service door: 步骤 3 中的图像 1,3 Base enclosure disassembly, Remove the service door: 步骤 3 中的图像 2,3 Base enclosure disassembly, Remove the service door: 步骤 3 中的图像 3,3
    • With an opening tool pry off the tabs that secure the service door to the base enclosure. Start with the long edge.
    • Continue along the short edges.
    • Once you have pried the service door off as it is in pic#3, it will come out of the rear edge very easily.
  4. Base enclosure disassembly, Identify the components: 步骤 4 中的图像 1,1
    • RAM memory modules
    • HDD (Hard Disk Drive)
    • mSATA SSD slot
    • Wifi & BT module (Wireless card)
  5. Base enclosure disassembly, Remove the hard disk: 步骤 5 中的图像 1,3 Base enclosure disassembly, Remove the hard disk: 步骤 5 中的图像 2,3 Base enclosure disassembly, Remove the hard disk: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    • Are you grounded? If yes, using a spudger, flip up the small black locking flap of the hard disk's ZIF connector.
    • Afterwards, using a pair of tweezers, grab the HDD's SATA cable at the transparent tab and simply lift its end up, out of the connector.
    • By levering with an opening tool, pry the HDD out of its bay. Once it is on your hand, release its cable from its retaining hole obtained on the base enclosure and finally leave the HDD aside.
  6. Base enclosure disassembly, ( If present, remove the mSATA SSD ): 步骤 6 中的图像 1,3 Base enclosure disassembly, ( If present, remove the mSATA SSD ): 步骤 6 中的图像 2,3 Base enclosure disassembly, ( If present, remove the mSATA SSD ): 步骤 6 中的图像 3,3
    • Using a PH#00 screwdriver remove the Phillips PM 2.0x2.5 screw which secures the SSD to the base enclosure: the SSD module will tilt up immediately.
    • Once the module is standing ─ if you're grounded ─ grab it with your fingers as it is shown in pic#3 and slowly pull it out of its connector maintaining its inclination.
    • On top of the previous movement - and always maintaining the SSD tilted - you have to lightly move the module back and forward as the blue arrow shows: think of a pendulum.
  7. Base enclosure disassembly, Remove the screws of the service door's area & battery bay: 步骤 7 中的图像 1,2 Base enclosure disassembly, Remove the screws of the service door's area & battery bay: 步骤 7 中的图像 2,2
    • Using a PH#00 screwdriver remove the two Phillips PM2.5x5 screws of the service door area. Group these screws together.
    • Using a PH#00 screwdriver remove the three remaining Phillips PM2.5x3 screws of the service door area. Group these screws together.
    • Using a PH#000 screwdriver remove the seven small Phillips PM1.5x2 screws of the battery bay. Group these screws together.
  8. Base enclosure disassembly, Remove the remaining screws that secure the base enclosure: 步骤 8 中的图像 1,2 Base enclosure disassembly, Remove the remaining screws that secure the base enclosure: 步骤 8 中的图像 2,2
    • Pry both of the top rubber pads off with a metal spudger. They are attached to the base enclosure with adhesive.
    • When you will be installing these two rubber pads again, pay attention to their difference. Search for the letter "R" impressed on the base of one of them and stick that one in the bay which displays the "R".
    • Using a PH#00 screwdriver remove then the eight Phillips PM2.5x5 screws that secure the base enclosure to the laptop. Group these screws together.
  9. Base enclosure disassembly, Dismount the base enclosure: 步骤 9 中的图像 1,2 Base enclosure disassembly, Dismount the base enclosure: 步骤 9 中的图像 2,2
    • By gently levering with opening tools, disengage the tabs that secure the base enclosure to the laptop. Start with the longer edge. Feel free to use your hands and to lift or turn the laptop if you like.
    • Once you have completed the long edge, proceed along the short edges. When also these two sides will be detached, the base enclosure will come out from the bottom edge with ease.
    • It is very likely that tabs break down during this operation. Once you have removed the base enclosure, look for broken tabs pieces inside the laptop. If you find them, remove them straight away: they could manage to hide somewhere and cause damages in the future.
结论
另外一个人完成了本指南。
Roberto Bartolacci
于02/10/18注册
1,518 声望
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 633
