跳转到主内容
Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement
你所需要的
  1. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Disconnect the spark plug wire: 步骤 1 中的图像 1,2 Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Disconnect the spark plug wire: 步骤 1 中的图像 2,2
    • Before you begin, ensure that the engine is powered down and cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Flip the engine switch to the off position: 步骤 2 中的图像 1,2 Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Flip the engine switch to the off position: 步骤 2 中的图像 2,2
    • Flip the red engine ON/OFF switch to the OFF position.
  3. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Close the fuel valve: 步骤 3 中的图像 1,2 Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Close the fuel valve: 步骤 3 中的图像 2,2
    • Flip the fuel valve lever to the OFF position.
  4. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Turn off the ignition: 步骤 4 中的图像 1,2 Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Turn off the ignition: 步骤 4 中的图像 2,2
    • Flip the ignition switch to the OFF position.
    • Ensure the wheel drive control lever is set to the neutral position.
  5. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Allow the wheels to freewheel: 步骤 5 中的图像 1,3 Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Allow the wheels to freewheel: 步骤 5 中的图像 2,3 Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Allow the wheels to freewheel: 步骤 5 中的图像 3,3
    • Pull the locking pin out and rotate it 90˚ to unlock the right wheel from the hub.
    • Repeat for the left wheel.
  6. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Add wheel chocks: 步骤 6 中的图像 1,1
    • Insert wheel chocks underneath each wheel to keep the device stationary during disassembly.
  7. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Remove the grease fitting: 步骤 7 中的图像 1,1
    • Use an 8 mm socket to remove the outboard bearing grease fitting.
  8. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Remove the side plate bolts: 步骤 8 中的图像 1,2 Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Remove the side plate bolts: 步骤 8 中的图像 2,2
    • Use a 9/16 inch socket to remove the four bolts securing the tine shaft to the side plate.
    • Use a 9/16 socket and wrench to remove the five bolts and accompanying nuts securing the side plate to the frame, three on the outside and two in the wheel well.
  9. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Tilt the tiller: 步骤 9 中的图像 1,2 Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Tilt the tiller: 步骤 9 中的图像 2,2
    • Tilt the tiller up so the motor side is resting on the work surface with the tines raised.
  10. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Remove the tine cover bolts: 步骤 10 中的图像 1,1
    • Use a 1/2 inch socket and wrench to remove the four bolts and accompanying nuts securing the side plate to the tine cover.
  11. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Remove the side plate: 步骤 11 中的图像 1,3 Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Remove the side plate: 步骤 11 中的图像 2,3 Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Remove the side plate: 步骤 11 中的图像 3,3
    • Slide the side plate down and away from the device to remove it.
  12. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Clean the assembly: 步骤 12 中的图像 1,2 Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Clean the assembly: 步骤 12 中的图像 2,2
    • Use a clean paper towel or shop rag to remove the grease from the outboard bearing assembly.
  13. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Remove the outboard bearing assembly bolt: 步骤 13 中的图像 1,1
    • Use a 9/16 inch socket to remove the bolt securing the outboard bearing assembly to the tine shaft.
  14. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Remove the washers: 步骤 14 中的图像 1,1
    • Remove the three washers, held in place by the bolt, from the outboard bearing assembly.
  15. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Remove the outboard bearing assembly: 步骤 15 中的图像 1,2 Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Remove the outboard bearing assembly: 步骤 15 中的图像 2,2
    • Pull the assembly off of the tine shaft to remove it.
结论
Carsten Frauenheim
于03/10/20注册
113,715 声望
创作了338篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 32
总计 374
