跳转到主内容
Barnes And Noble Nook HD Tablet Screen Replacement
你所需要的
  1. Barnes And Noble Nook HD Tablet Screen Replacement, Remove the front screen: 步骤 1 中的图像 1,3 Barnes And Noble Nook HD Tablet Screen Replacement, Remove the front screen: 步骤 1 中的图像 2,3 Barnes And Noble Nook HD Tablet Screen Replacement, Remove the front screen: 步骤 1 中的图像 3,3
    • wedge the plastic opening piece underneath the bottom left hand corner of the front frame. Pry the frame off of the Nook.
  2. Barnes And Noble Nook HD Tablet Screen Replacement, Remove the screws: 步骤 2 中的图像 1,2 Barnes And Noble Nook HD Tablet Screen Replacement, Remove the screws: 步骤 2 中的图像 2,2
    • Remove every visible screw tying the chassis to the bottom frame using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
  3. Barnes And Noble Nook HD Tablet Screen Replacement, Remove the chassis: 步骤 3 中的图像 1,1
  4. Barnes And Noble Nook HD Tablet Screen Replacement, Detach battery: 步骤 4 中的图像 1,1
    • detach the battery ribbon from the motherboard.
  5. Barnes And Noble Nook HD Tablet Screen Replacement, Flip the nook: 步骤 5 中的图像 1,1
    • flip center chassis so that the back of the screen is facing you, and the hole is positioned in the bottom right corner.
  6. Barnes And Noble Nook HD Tablet Screen Replacement, Detach the screen from chassis part 1: 步骤 6 中的图像 1,3 Barnes And Noble Nook HD Tablet Screen Replacement, Detach the screen from chassis part 1: 步骤 6 中的图像 2,3 Barnes And Noble Nook HD Tablet Screen Replacement, Detach the screen from chassis part 1: 步骤 6 中的图像 3,3
    • Remove copper tape above the antenna, 3 quarters of the way up the left side of the nook.
  7. Barnes And Noble Nook HD Tablet Screen Replacement, Detach the screen from chassis part 2: 步骤 7 中的图像 1,2 Barnes And Noble Nook HD Tablet Screen Replacement, Detach the screen from chassis part 2: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    • Locate thin orange strip on the top side of the motherboard. Apply tweezers to the black casing that locks it into the motherboard (plastic piece will completely come out).
  8. Barnes And Noble Nook HD Tablet Screen Replacement, Detach the screen from chassis part 3: 步骤 8 中的图像 1,2 Barnes And Noble Nook HD Tablet Screen Replacement, Detach the screen from chassis part 3: 步骤 8 中的图像 2,2
    • Locate the foam covered orange strip on the motherboard. Pull up (away from motherboard) so that it i no longer connected to the motherboard.
  9. Barnes And Noble Nook HD Tablet Screen Replacement, Take motherboard away from the screen: 步骤 9 中的图像 1,2 Barnes And Noble Nook HD Tablet Screen Replacement, Take motherboard away from the screen: 步骤 9 中的图像 2,2
    • Lift motherboard away from the screen. Pull frame off of the screen.
  10. Barnes And Noble Nook HD Tablet Screen Replacement, Place new screen: 步骤 10 中的图像 1,2 Barnes And Noble Nook HD Tablet Screen Replacement, Place new screen: 步骤 10 中的图像 2,2
    • Put the new screen back into place in the frame (the reverse of step 9). Place motherboard back into place on the back of the screen. And follow steps in reverse order to reassemble.
结论
9等其他人完成本指南。
Elijah Gonsalves
于10/24/14注册
1,049 声望
创作了3篇指南
团队
UMass Dartmouth, Team 2-3, Duarte Fall 2014 UMass Dartmouth, Team 2-3, Duarte Fall 2014 的会员
UMASSD-DUARTE-F14S2G3
5 名成员
创作了10篇指南
1指南评论
como faço para comprar a tela touch do tablet nook ce0984
sou de Fortaleza-Ceara - Brasil
meu e-mail é moreiragenesio@yahoo.com.br
moreiragenesio - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 26
总计 14,654
