跳转到主内容
Barbie Doll Hair Replacement
你所需要的
  1. Barbie Doll Hair Replacement, Barbie Doll Hair: 步骤 1 中的图像 1,3 Barbie Doll Hair Replacement, Barbie Doll Hair: 步骤 1 中的图像 2,3 Barbie Doll Hair Replacement, Barbie Doll Hair: 步骤 1 中的图像 3,3
    • Use light force to pull barbie head off of the body.
    • If stuck, soak in warm water to loosen.
  2. Barbie Doll Hair Replacement: 步骤 2 中的图像 1,2 Barbie Doll Hair Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Cut off all of the remaining hair using scissors.
    • Tweezers may be used once hair is too short for scissors.
    • It is important to remove as much hair as possible.
  3. Barbie Doll Hair Replacement: 步骤 3 中的图像 1,3 Barbie Doll Hair Replacement: 步骤 3 中的图像 2,3 Barbie Doll Hair Replacement: 步骤 3 中的图像 3,3
    • Cut the yarn pieces for doll hair.
    • With a ruler, measure equal pieces twice as long as intended hair length.
    • Cut enough for desired hair thickness.
    • To make up for inconsistencies in length, you may cut pieces longer and trim later.
  4. Barbie Doll Hair Replacement: 步骤 4 中的图像 1,3 Barbie Doll Hair Replacement: 步骤 4 中的图像 2,3 Barbie Doll Hair Replacement: 步骤 4 中的图像 3,3
    • Thread yarn between the forked tip of the reroot tool.
    • Attempt to thread the yarn at its midpoint for more even hair.
    • Insert the reroot tool into a small hole atop the doll's head.
    • Push the yarn inside as far as the tool will allow.
    • Remove the reroot tool from the head, leaving the yarn tucked inside.
  5. Barbie Doll Hair Replacement: 步骤 5 中的图像 1,1
    • Add glue to the inside of the doll's head.
    • Plug in and preheat the glue gun.
    • Insert glue gun from the base of the head.
    • Add a thicker layer of glue for stronger hair.
    • Hot glue can cause burns when exposed directly to skin.
  6. Barbie Doll Hair Replacement: 步骤 6 中的图像 1,1
    • After applying glue, use the blunt end of the rerooting tool to spread glue to cover the inside of the head.
    • Do this immediately after applying glue, because it will dry quickly.
  7. Barbie Doll Hair Replacement: 步骤 7 中的图像 1,2 Barbie Doll Hair Replacement: 步骤 7 中的图像 2,2
    • Wait for the glue to dry (15-30 minutes).
    • Once the glue is dry, attach the Barbie head back onto the neck joint.
    • For extra styling and volume, you may separate yarn strands.
终点
另外一个人完成了本指南。
Miranda Comstock
于01/31/23注册
170 声望
撰写一个指南
团队
UC Davis, Team 2-3, Andersen Winter 2023 UC Davis, Team 2-3, Andersen Winter 2023 的会员
UCD-ANDERSEN-W23S2G3
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 68
总计 1,742
