简介
The ball bearings reduce the friction caused by the rotating wheel by concentrating it on rolling bearings, in this case there are ten on each side of the axle. Well maintained ball bearings will help the wheel spin more freely and allow for an easier and smoother ride.
Notes:
- When cleaning the bearings and cones, solvents like kerosene can be very effective, however, just a wipe down with a rag is sufficient.
- When the wheel is assembles correctly there should be very little resistance between the axle and the wheel and each should spin freely of the other.
- Some of these steps require near-perfect alignment. They may take several tries to get right, so patience is a must.
你所需要的
Unscrew the quick release nut from the quick release axle. Remove the quick release axle.
After removing the axle you should notice that there are two springs on it. Be careful not to lose these.
3等其他人完成本指南。
一条评论
Display and text were really helpful. I was wondering what happened to the sprocket assembly. from steps 1 through 3. This worked fine for the front wheel when I did it, but I'm not sure about working on the rear wheel. Does the sprocket assembly stay on the axle when you take off the lock nut and cone from the other side? Thanks Bob
