跳转到主内容
Backbone One Right Bumper Replacement
你所需要的
  1. Backbone One Right Bumper Replacement, Remove the screws: 步骤 1 中的图像 1,1
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
  2. Backbone One Right Bumper Replacement, Rotate the upper part: 步骤 2 中的图像 1,3 Backbone One Right Bumper Replacement, Rotate the upper part: 步骤 2 中的图像 2,3 Backbone One Right Bumper Replacement, Rotate the upper part: 步骤 2 中的图像 3,3
    • Lift up the upper cover of the controller.
    • Swing the upper cover over and place it on the controller case.
    • Make sure that the interconnecting cable has no tension.
  3. Backbone One Right Bumper Replacement, Remove the protective tape: 步骤 3 中的图像 1,3 Backbone One Right Bumper Replacement, Remove the protective tape: 步骤 3 中的图像 2,3 Backbone One Right Bumper Replacement, Remove the protective tape: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable and the connector.
  4. Backbone One Right Bumper Replacement, Open the interconnect cable ZIF connector: 步骤 4 中的图像 1,3 Backbone One Right Bumper Replacement, Open the interconnect cable ZIF connector: 步骤 4 中的图像 2,3 Backbone One Right Bumper Replacement, Open the interconnect cable ZIF connector: 步骤 4 中的图像 3,3
    • Use the tip of an opening pick to open the gray flap of the interconnect cable ZIF connector by pushing it upwards.
  5. Backbone One Right Bumper Replacement, Disconnect the interconnect cable: 步骤 5 中的图像 1,2 Backbone One Right Bumper Replacement, Disconnect the interconnect cable: 步骤 5 中的图像 2,2
    • Disconnect the cable by pulling it straight out the ZIF connector.
  6. Backbone One Right Bumper Replacement, Disconnect the phone connector cables: 步骤 6 中的图像 1,3 Backbone One Right Bumper Replacement, Disconnect the phone connector cables: 步骤 6 中的图像 2,3 Backbone One Right Bumper Replacement, Disconnect the phone connector cables: 步骤 6 中的图像 3,3
    • Use a pair of tweezers to disconnect the phone connector cables out from their sockets.
  7. Backbone One Right Bumper Replacement, Separate the upper case: 步骤 7 中的图像 1,1
    • Separate the the upper case of the left controller handle.
  8. Backbone One Right Bumper Replacement, Remove the screws: 步骤 8 中的图像 1,1
    • Use a Phillips screwdriver to remove the three 5.9 mm-long screws.
  9. Backbone One Right Bumper Replacement, Remove the trigger: 步骤 9 中的图像 1,2 Backbone One Right Bumper Replacement, Remove the trigger: 步骤 9 中的图像 2,2
    • Remove the trigger.
  10. Backbone One Right Bumper Replacement, Remove the bumper: 步骤 10 中的图像 1,2 Backbone One Right Bumper Replacement, Remove the bumper: 步骤 10 中的图像 2,2
    • Remove the bumper.
结论
Repair didn’t go as planned? Ask our Answers community for help.
Adriana Zwink
于12/18/19注册
62,444 声望
创作了167篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,738篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 612
