跳转到主内容
Backbone One Phone Connector Replacement
你所需要的
  1. Backbone One Phone Connector Replacement, Remove the screws: 步骤 1 中的图像 1,1
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
  2. Backbone One Phone Connector Replacement, Rotate the upper part: 步骤 2 中的图像 1,3 Backbone One Phone Connector Replacement, Rotate the upper part: 步骤 2 中的图像 2,3 Backbone One Phone Connector Replacement, Rotate the upper part: 步骤 2 中的图像 3,3
    • Lift up the upper cover of the controller.
    • Swing the upper cover over and place it on the controller case.
    • Make sure that the interconnecting cable has no tension.
  3. Backbone One Phone Connector Replacement, Remove the screws: 步骤 3 中的图像 1,1
    • Use a Phillips screwdriver to remove the two 4.8 mm-long screws securing the phone connector.
  4. Backbone One Phone Connector Replacement, Unthread the phone connector: 步骤 4 中的图像 1,3 Backbone One Phone Connector Replacement, Unthread the phone connector: 步骤 4 中的图像 2,3 Backbone One Phone Connector Replacement, Unthread the phone connector: 步骤 4 中的图像 3,3
    • Use your fingers to thread the phone connecter through the opening in the plastic cover at the right side of the rear cover.
  5. Backbone One Phone Connector Replacement, Disconnect the phone connector cable: 步骤 5 中的图像 1,2 Backbone One Phone Connector Replacement, Disconnect the phone connector cable: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to disconnect the first phone connector cable from the mainboard.
  6. Backbone One Phone Connector Replacement, Disconnect the phone connector cable: 步骤 6 中的图像 1,2 Backbone One Phone Connector Replacement, Disconnect the phone connector cable: 步骤 6 中的图像 2,2
    • Use a pair of tweezers to disconnect the second phone connector cable from the mainboard.
  7. Backbone One Phone Connector Replacement, Remove the phone connector cable: 步骤 7 中的图像 1,1
    • Remove the phone connector cable.
结论
Repair didn’t go as planned? Ask our Answers community for help.
另外一个人完成了本指南。
Adriana Zwink
于12/18/19注册
62,316 声望
创作了167篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,649篇指南
6指南评论
Where can i buy a new part
reye_s - 回复
Unfortunately we haven't found any replacement parts yet. If you find a website that offers replacement parts feel free to share your experience with us.
Adriana Zwink -
Where can I find the connector
Big_deppresion_time_14 Xxx - 回复
My son bent the connector cable. Where do I buy a new one?
Please update as soon as possible!
Krystal Glavic - 回复
Has anyone found a place to buy a replacement lightning connector yet?
Ump_ - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 24
过去 30 天: 151
总计 5,085
