跳转到主内容
加入维修社区 - 创建账户
Backbone One Left Trigger Replacement
你所需要的
  1. Backbone One Left Trigger Replacement, Unfasten the screws: 步骤 1 中的图像 1,1
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
  2. Backbone One Left Trigger Replacement, Rotate the upper cover: 步骤 2 中的图像 1,3 Backbone One Left Trigger Replacement, Rotate the upper cover: 步骤 2 中的图像 2,3 Backbone One Left Trigger Replacement, Rotate the upper cover: 步骤 2 中的图像 3,3
    • Lift up the upper part of the controller.
    • Swing over the upper cover and place it on the controller case.
    • Take care that the interconnecting cable has no tension.
  3. Backbone One Left Trigger Replacement, Remove the protective tape: 步骤 3 中的图像 1,3 Backbone One Left Trigger Replacement, Remove the protective tape: 步骤 3 中的图像 2,3 Backbone One Left Trigger Replacement, Remove the protective tape: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable connector.
  4. Backbone One Left Trigger Replacement, Open the ZIF connector: 步骤 4 中的图像 1,2 Backbone One Left Trigger Replacement, Open the ZIF connector: 步骤 4 中的图像 2,2
    • Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
  5. Backbone One Left Trigger Replacement, Disconnect the interconnect cable: 步骤 5 中的图像 1,2 Backbone One Left Trigger Replacement, Disconnect the interconnect cable: 步骤 5 中的图像 2,2
    • Use your fingers to disconnect the interconnect cable from its connector.
  6. Backbone One Left Trigger Replacement: 步骤 6 中的图像 1,2 Backbone One Left Trigger Replacement: 步骤 6 中的图像 2,2
    • Remove the upper half of the left controller assembly.
  7. Backbone One Left Trigger Replacement, Remove the screw: 步骤 7 中的图像 1,2 Backbone One Left Trigger Replacement, Remove the screw: 步骤 7 中的图像 2,2
    • Use a Phillips screwdriver to remove the 5.9 mm-long screw which is securing the trigger.
    • The screw is difficult to reach. Insert the screwdriver at an angle of 45 degrees.
  8. Backbone One Left Trigger Replacement, Remove the trigger: 步骤 8 中的图像 1,2 Backbone One Left Trigger Replacement, Remove the trigger: 步骤 8 中的图像 2,2
    • Remove the left trigger.
结论
Repair didn’t go as planned? Ask our Answers community for help.
2等其他人完成本指南。
Adriana Zwink
于12/18/19注册
63,295 声望
创作了167篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,926篇指南
1指南评论
Where can I buy the trigger
Zach - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 20
过去 30 天: 90
总计 3,559
