跳转到主内容
Backbone One Left Mainboard Replacement
你所需要的
  1. Backbone One Left Mainboard Replacement, Unfasten the screws: 步骤 1 中的图像 1,1
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
  2. Backbone One Left Mainboard Replacement, Rotate the upper cover: 步骤 2 中的图像 1,3 Backbone One Left Mainboard Replacement, Rotate the upper cover: 步骤 2 中的图像 2,3 Backbone One Left Mainboard Replacement, Rotate the upper cover: 步骤 2 中的图像 3,3
    • Lift up the upper part of the controller.
    • Swing over the upper cover and place it on the controller case.
    • Take care that the interconnecting cable has no tension.
  3. Backbone One Left Mainboard Replacement, Remove the protective tape: 步骤 3 中的图像 1,3 Backbone One Left Mainboard Replacement, Remove the protective tape: 步骤 3 中的图像 2,3 Backbone One Left Mainboard Replacement, Remove the protective tape: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable connector.
  4. Backbone One Left Mainboard Replacement, Open the ZIF connector: 步骤 4 中的图像 1,2 Backbone One Left Mainboard Replacement, Open the ZIF connector: 步骤 4 中的图像 2,2
    • Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
  5. Backbone One Left Mainboard Replacement, Disconnect the interconnect cable: 步骤 5 中的图像 1,2 Backbone One Left Mainboard Replacement, Disconnect the interconnect cable: 步骤 5 中的图像 2,2
    • Use your fingers to disconnect the interconnect cable from its connector.
  6. Backbone One Left Mainboard Replacement: 步骤 6 中的图像 1,2 Backbone One Left Mainboard Replacement: 步骤 6 中的图像 2,2
    • Remove the upper half of the left controller assembly.
  7. Backbone One Left Mainboard Replacement, Remove the screw: 步骤 7 中的图像 1,2 Backbone One Left Mainboard Replacement, Remove the screw: 步骤 7 中的图像 2,2
    • Use a Phillips screwdriver to remove the 5.9 mm-long screw which is securing the trigger.
    • The screw is difficult to reach. Insert the screwdriver at an angle of 45 degrees.
  8. Backbone One Left Mainboard Replacement, Remove the trigger: 步骤 8 中的图像 1,2 Backbone One Left Mainboard Replacement, Remove the trigger: 步骤 8 中的图像 2,2
    • Remove the left trigger.
  9. Backbone One Left Mainboard Replacement, Remove the bumper: 步骤 9 中的图像 1,2 Backbone One Left Mainboard Replacement, Remove the bumper: 步骤 9 中的图像 2,2
    • Use your fingers to remove the left bumper.
  10. Backbone One Left Mainboard Replacement, Remove the screws: 步骤 10 中的图像 1,1
    • Use a Phillips screwdriver to remove the four 3.9 mm-long screws.
  11. Backbone One Left Mainboard Replacement, Remove the mainboard: 步骤 11 中的图像 1,2 Backbone One Left Mainboard Replacement, Remove the mainboard: 步骤 11 中的图像 2,2
    • Remove the mainboard.
结论
Repair didn’t go as planned? Ask our Answers community for help.
2等其他人完成本指南。
Adriana Zwink
于12/18/19注册
62,569 声望
创作了167篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,786篇指南
1指南评论
In my unit, there were two more screws at step (10), in the upper part of the controller, near the trigger. They may have changed the number of screws used in manufacturing at some point.
Mario - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 23
过去 30 天: 76
总计 2,939
