当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Now that the base of the bookshelf is back together, we will need to measure out the size of board needed for the new backing.
Use the measuring tape and the square ruler to measure out the specific size you need. Use a pencil to draw the lines out so you can saw the piece out with precision.
Use the jig saw to cut the piece of plywood out following the lines you just drew.
即将完成!
终点
2等其他人完成本指南。
