跳转到主内容
Back Panel Removal
你所需要的
  1. Back Panel Removal, Back Panel Removal: 步骤 1 中的图像 1,2 Back Panel Removal, Back Panel Removal: 步骤 1 中的图像 2,2
    • Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
  2. Back Panel Removal: 步骤 2 中的图像 1,1
    • Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
  3. Back Panel Removal: 步骤 3 中的图像 1,1
    • Use the spudger to pry apart the screen from all around the device.
    • Gently lift the screen so not to disconnect the ribbon attaching the screen to the motherboard.
终点
另外一个人完成了本指南。
团队
USF Tampa, Team 1-3, Lacy Fall 2016 USF Tampa, Team 1-3, Lacy Fall 2016 的会员
USFT-LACY-F16S1G3
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 1,018
