跳转到主内容
Back Panel Disassembly
你所需要的
  1. Back Panel Disassembly, Back Panel Disassembly: 步骤 1 中的图像 1,2 Back Panel Disassembly, Back Panel Disassembly: 步骤 1 中的图像 2,2
    • With the battery door facing upward, take your PH000 screwdriver and remove the 4 mm screws from the bottom of the device.
  2. Back Panel Disassembly: 步骤 2 中的图像 1,2 Back Panel Disassembly: 步骤 2 中的图像 2,2
    • After removing the screws, rotate the device to where the micro USB port is facing up.
    • Now, take your PH000 screwdriver and remove the two 4 mm screws from the device.
  3. Back Panel Disassembly: 步骤 3 中的图像 1,2 Back Panel Disassembly: 步骤 3 中的图像 2,2
    • Rotate the device 180 degrees so that the opposite side of the device is now facing upwards.
  4. Back Panel Disassembly: 步骤 4 中的图像 1,2 Back Panel Disassembly: 步骤 4 中的图像 2,2
    • After all of the screws are removed, rotate the device so that the bottom of the device is now facing upward.
    • With your index finger, press down and slide open the memory card/battery door.
  5. Back Panel Disassembly: 步骤 5 中的图像 1,3 Back Panel Disassembly: 步骤 5 中的图像 2,3 Back Panel Disassembly: 步骤 5 中的图像 3,3
    • Now take the plastic opening tool, and place it in the seam of the device.
    • Now, work the tool around the seam of the device until you can safely pry open the device.
  6. Back Panel Disassembly: 步骤 6 中的图像 1,2 Back Panel Disassembly: 步骤 6 中的图像 2,2
    • Be careful when removing the back piece of your device.
    • Using your free hand, finish prying off the back piece of the device.
结论
2等其他人完成本指南。
Jordan Rosemeyer
于10/13/15注册
491 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 633
