跳转到主内容
Back Cover Replacement
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,3 Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,3 Back Cover Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Insert the plastic opening tool into the middle of the bottom edge of the device. The tool should be inserted within the seam between the back and front covers.
    • Slide the opening tool to the right and slowly continue to separate the back cover from the device.
    • Avoid prying on the buttons, as they are easily damaged.
  2. Back Cover Replacement: 步骤 2 中的图像 1,1
    • Pull the cover off of the device once about three quarters of the cover has been pried open using the plastic opening tool.
结论
To reassemble your device, place the back cover in place and apply gentle pressure to snap the cover back on the device.
Walker Karstens
于10/30/16注册
364 声望
创作了3篇指南
团队
Baylor, Team 4-1, Williams Fall 2016 Baylor, Team 4-1, Williams Fall 2016 的会员
BU-WILLIAMS-F16S4G1
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 86
