跳转到主内容
Back Cover Replacement
你所需要的
  1. Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Power off Zoomer Dino Boomer before disassembly.
    • Remove the eight 9.3mm Phillips #1 screws.
  2. Back Cover Replacement: 步骤 2 中的图像 1,2 Back Cover Replacement: 步骤 2 中的图像 2,2
    • Turn dinosaur over and hold upright.
    • Use the spudger to pry apart the back cover from the remainder of the Zoomer Dino Boomer.
    • Be gentle while removing the back cover. The back cover of the Zoomer Dino Boomer is still connected to the electronic system by a wire.
  3. Back Cover Replacement: 步骤 3 中的图像 1,3 Back Cover Replacement: 步骤 3 中的图像 2,3 Back Cover Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    • Disconnect the wire that connects the back cover of the dino to the main circuit board by carefully pulling on the orange wire connector with tweezers.
    • Remove back cover.
    • If you are having difficulty removing the connector from its socket, push in the small tabs on the side of the connector with the tweezers. This step may take some work.
    • Do not damage the wires or circuit board.
结论
另外一个人完成了本指南。
团队
USF Tampa, Team 16-1, Wollert Fall 2015 USF Tampa, Team 16-1, Wollert Fall 2015 的会员
USFT-WOLLERT-F15S16G1
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 15
总计 879
