跳转到主内容
加入维修社区 - 创建账户
Baby Taylor Guitar String Replacement
你所需要的
  1. Baby Taylor Guitar String Replacement, Guitar String Replacement: 步骤 1 中的图像 1,3 Baby Taylor Guitar String Replacement, Guitar String Replacement: 步骤 1 中的图像 2,3 Baby Taylor Guitar String Replacement, Guitar String Replacement: 步骤 1 中的图像 3,3
    • Rotate the tuner of the string you want to replace in a clockwise direction until it's loose.
    • You can either do it by hand (First Picture) or you can use the guitar string winder (Second picture).
  2. Baby Taylor Guitar String Replacement: 步骤 2 中的图像 1,2 Baby Taylor Guitar String Replacement: 步骤 2 中的图像 2,2
    • Grab a plier and pull out the bridge pin of the string you want to replace.
    • Make sure that you've completed step 1 first. The string has to be loose before doing this step.
  3. Baby Taylor Guitar String Replacement: 步骤 3 中的图像 1,3 Baby Taylor Guitar String Replacement: 步骤 3 中的图像 2,3 Baby Taylor Guitar String Replacement: 步骤 3 中的图像 3,3
    • Take out the string from the bridge and the tuning pin.
    • You can now throw away the string. You will not be needing it anymore.
  4. Baby Taylor Guitar String Replacement: 步骤 4 中的图像 1,2 Baby Taylor Guitar String Replacement: 步骤 4 中的图像 2,2
    • Grab the new string and place the end (ball-end) inside the bridge.
    • The ball-end of a string is the side of the string that has a ball shape. (Shown in picture 2)
  5. Baby Taylor Guitar String Replacement: 步骤 5 中的图像 1,2 Baby Taylor Guitar String Replacement: 步骤 5 中的图像 2,2
    • Place the bridge pin inside the bridge in order to lock in the new string.
    • Lightly hammer down the bridge pin to keep it from detaching.
  6. Baby Taylor Guitar String Replacement: 步骤 6 中的图像 1,2 Baby Taylor Guitar String Replacement: 步骤 6 中的图像 2,2
    • Cut the excess string with a plier.
    • Cut the string around 1.5 inches over the desired tuning pin. (Recommended by Taylor Guitars)
  7. Baby Taylor Guitar String Replacement: 步骤 7 中的图像 1,1
    • Place the new string inside the tuning pinhole.
    • It is recommended to place a really small portion of the string inside the pinhole to keep it from ripping your guitar bag. (As shown in the picture)
  8. Baby Taylor Guitar String Replacement: 步骤 8 中的图像 1,3 Baby Taylor Guitar String Replacement: 步骤 8 中的图像 2,3 Baby Taylor Guitar String Replacement: 步骤 8 中的图像 3,3
    • Rotate the tuners in a counter-clockwise direction to tighten the new string.
    • You can either tighten it by hand (First Picture) or you can use the guitar string winder (Second Picture).
  9. Baby Taylor Guitar String Replacement: 步骤 9 中的图像 1,1
    • Make sure your string is in tune and strum away!
结论
Most guitar strings de-tune after they’ve been recently replaced. Tune your strings every once in a while for a few days and the strings will stay in tune.
Mohamed Saleh
于09/18/21注册
230 声望
撰写一个指南
团队
York University, Team F-21, Woodhouse Fall 2021 York University, Team F-21, Woodhouse Fall 2021 的会员
YORK-WOODHOUSE-F21SFG21
1 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 42
总计 1,011
