跳转到主内容
Baby Einstein Take Along Tunes Battery Socket Replacement
你所需要的
  1. Baby Einstein Take Along Tunes Battery Socket Replacement, Battery Socket: 步骤 1 中的图像 1,1
    • Set the device on it's face with the back facing up.
  2. Baby Einstein Take Along Tunes Battery Socket Replacement: 步骤 2 中的图像 1,1
    • Begin by removing all highlighted screws with a using a Phillips #1 Screwdriver.
  3. Baby Einstein Take Along Tunes Battery Socket Replacement: 步骤 3 中的图像 1,1
    • Remove the battery plate with a plastic opening tool and set it aside.
  4. Baby Einstein Take Along Tunes Battery Socket Replacement: 步骤 4 中的图像 1,1
    • Remove each battery with a plastic opening tool and set them aside.
  5. Baby Einstein Take Along Tunes Battery Socket Replacement: 步骤 5 中的图像 1,1
    • Separate the device in two parts by using the plastic opening tool.
  6. Baby Einstein Take Along Tunes Battery Socket Replacement: 步骤 6 中的图像 1,1
    • Remove the top piece and place it aside, keeping the bottom half with the mechanics.
  7. Baby Einstein Take Along Tunes Battery Socket Replacement: 步骤 7 中的图像 1,1
    • Remove the highlighted screws using a Phillips #1 Screwdriver.
  8. Baby Einstein Take Along Tunes Battery Socket Replacement: 步骤 8 中的图像 1,1
    • Use the plastic opening tool and carefully set the LED panel to the side, exposing the wires underneath.
  9. Baby Einstein Take Along Tunes Battery Socket Replacement: 步骤 9 中的图像 1,1
    在这个步骤中使用的工具:
    • With the precision tweezers, straighten the metal connectors to remove the terminals from the other side.
  10. Baby Einstein Take Along Tunes Battery Socket Replacement: 步骤 10 中的图像 1,2 Baby Einstein Take Along Tunes Battery Socket Replacement: 步骤 10 中的图像 2,2
    • Sever the red wire from the metal connector with the precision tweezers.
  11. Baby Einstein Take Along Tunes Battery Socket Replacement: 步骤 11 中的图像 1,2 Baby Einstein Take Along Tunes Battery Socket Replacement: 步骤 11 中的图像 2,2
    • Sever the black wire from the metal connector with the precision tweezers.
  12. Baby Einstein Take Along Tunes Battery Socket Replacement: 步骤 12 中的图像 1,2 Baby Einstein Take Along Tunes Battery Socket Replacement: 步骤 12 中的图像 2,2
    • Flip the device on its face and remove the battery terminals with a metal spudger.
结论
Shreya Sunny
于09/04/15注册
607 声望
创作了6篇指南
团队
USF Tampa, Team 2-2, Sullivan Fall 2015 USF Tampa, Team 2-2, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S2G2
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 685
