跳转到主内容
BRCK v1 Motherboard Replacement
你所需要的
  1. BRCK v1 Motherboard  Replacement, Antenna: 步骤 1 中的图像 1,1
    • Stand the device on its side so the antenna is sitting on the top.
  2. BRCK v1 Motherboard  Replacement: 步骤 2 中的图像 1,2 BRCK v1 Motherboard  Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    • Use the tweezers to grip the neck of the antenna(the part closest to the device).
    • Use opposite hand to twist off the body of the antenna.
  3. BRCK v1 Motherboard  Replacement, Top Cover: 步骤 3 中的图像 1,1
    • Place the face of the device showing BRCK face up.
  4. BRCK v1 Motherboard  Replacement: 步骤 4 中的图像 1,1
    • Remove the four screws(4mm hex head) on the corners of the device with a Hex 2.0 Screwdriver.
  5. BRCK v1 Motherboard  Replacement: 步骤 5 中的图像 1,1
    • Remove the top cover.
  6. BRCK v1 Motherboard  Replacement, Modem: 步骤 6 中的图像 1,1
    • Cut the black zip tie holding the modem down.
    • Caution By cutting the zip tie, you void any manufacturer warranty you may have on the device.
  7. BRCK v1 Motherboard  Replacement: 步骤 7 中的图像 1,1
    • Remove the connection located on the edge of the modem.
  8. BRCK v1 Motherboard  Replacement: 步骤 8 中的图像 1,2 BRCK v1 Motherboard  Replacement: 步骤 8 中的图像 2,2
    • Slightly lift the modem to reveal the brown ribbon connector and metal connection plate, located on the bottom of the modem.
  9. BRCK v1 Motherboard  Replacement: 步骤 9 中的图像 1,3 BRCK v1 Motherboard  Replacement: 步骤 9 中的图像 2,3 BRCK v1 Motherboard  Replacement: 步骤 9 中的图像 3,3
    在这个步骤中使用的工具:
    • Using your tweezers, gently push on the metal plate and slide it down toward the base of the modem to release the locking mechanism.
    • Lower the plate and gently pull the ribbon out of the face plate.
    • Caution Be extremely gentle while preforming this step. The ribbon is brittle and prone to breaking if bent too much. Make sure you go slowly so that you do not damage the device.
  10. BRCK v1 Motherboard  Replacement: 步骤 10 中的图像 1,2 BRCK v1 Motherboard  Replacement: 步骤 10 中的图像 2,2
    • Remove the modem from the device.
  11. BRCK v1 Motherboard  Replacement, Motherboard: 步骤 11 中的图像 1,2 BRCK v1 Motherboard  Replacement, Motherboard: 步骤 11 中的图像 2,2
    • Remove the nut and washer from the RF connector, located where the antenna was connected.
  12. BRCK v1 Motherboard  Replacement: 步骤 12 中的图像 1,2 BRCK v1 Motherboard  Replacement: 步骤 12 中的图像 2,2
    • Unplug the red, black, and yellow wire connection by lifting up.
  13. BRCK v1 Motherboard  Replacement: 步骤 13 中的图像 1,3 BRCK v1 Motherboard  Replacement: 步骤 13 中的图像 2,3 BRCK v1 Motherboard  Replacement: 步骤 13 中的图像 3,3
    在这个步骤中使用的工具:
    • Carefully insert tweezers under the black tab, and lift to release the clip.
    • Slide the ribbon out from under the clip to free the motherboard.
  14. BRCK v1 Motherboard  Replacement: 步骤 14 中的图像 1,1
    • Remove outside rubber covers by lifting them out of place.
  15. BRCK v1 Motherboard  Replacement: 步骤 15 中的图像 1,3 BRCK v1 Motherboard  Replacement: 步骤 15 中的图像 2,3 BRCK v1 Motherboard  Replacement: 步骤 15 中的图像 3,3
    • Slowly lift the motherboard out from the device by lifting it from the end next to the ribbon connection.
    • Lift and pull out of place.
结论
Jeret Buerger
于04/01/15注册
501 声望
创作了5篇指南
团队
Cal Poly, Team 12-3, Lancaster Spring 2015 Cal Poly, Team 12-3, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S12G3
3 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 330
