跳转到主内容
BRCK v1 Modem Ribbon Connector Replacement
你所需要的
  1. BRCK v1 Modem Ribbon Connector Replacement, Top Cover: 步骤 1 中的图像 1,1
    • Place the face of the device showing BRCK face up.
  2. BRCK v1 Modem Ribbon Connector Replacement: 步骤 2 中的图像 1,1
    • Remove the four screws(4mm hex head) on the corners of the device with a Hex 2.0 Screwdriver.
  3. BRCK v1 Modem Ribbon Connector Replacement: 步骤 3 中的图像 1,1
    • Remove the top cover.
  4. BRCK v1 Modem Ribbon Connector Replacement, Modem: 步骤 4 中的图像 1,1
    • Cut the black zip tie holding the modem down.
    • Caution By cutting the zip tie, you void any manufacturer warranty you may have on the device.
  5. BRCK v1 Modem Ribbon Connector Replacement: 步骤 5 中的图像 1,1
    • Remove the connection located on the edge of the modem.
  6. BRCK v1 Modem Ribbon Connector Replacement: 步骤 6 中的图像 1,2 BRCK v1 Modem Ribbon Connector Replacement: 步骤 6 中的图像 2,2
    • Slightly lift the modem to reveal the brown ribbon connector and metal connection plate, located on the bottom of the modem.
  7. BRCK v1 Modem Ribbon Connector Replacement: 步骤 7 中的图像 1,3 BRCK v1 Modem Ribbon Connector Replacement: 步骤 7 中的图像 2,3 BRCK v1 Modem Ribbon Connector Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    • Using your tweezers, gently push on the metal plate and slide it down toward the base of the modem to release the locking mechanism.
    • Lower the plate and gently pull the ribbon out of the face plate.
    • Caution Be extremely gentle while preforming this step. The ribbon is brittle and prone to breaking if bent too much. Make sure you go slowly so that you do not damage the device.
  8. BRCK v1 Modem Ribbon Connector Replacement: 步骤 8 中的图像 1,2 BRCK v1 Modem Ribbon Connector Replacement: 步骤 8 中的图像 2,2
    • Remove the modem from the device.
  9. BRCK v1 Modem Ribbon Connector Replacement, Modem Ribbon Connector: 步骤 9 中的图像 1,3 BRCK v1 Modem Ribbon Connector Replacement, Modem Ribbon Connector: 步骤 9 中的图像 2,3 BRCK v1 Modem Ribbon Connector Replacement, Modem Ribbon Connector: 步骤 9 中的图像 3,3
    • Using your fingers, apply equal force to each side of the black tab to loosen the connection.
    • Slide the ribbon out from under the black tab.
结论
Jeret Buerger
于04/01/15注册
501 声望
创作了5篇指南
团队
Cal Poly, Team 12-3, Lancaster Spring 2015 Cal Poly, Team 12-3, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S12G3
3 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 265
